Center rear light bar install - so cal
gregeast
Greg
Colorado, USA
2022 Taycan GTS
Does retrofitting the red lightbar also enable the fancy animation when you lock/unlock the car like the 2025 models?
mystermykee
Bay Area
9j1, 9y0 hybrid, 992.1
Yes. The TSB shows that LIN wiring as well as coding is needed. You can attempt a DIY by wiring each of the LIN connectors in each of the tail lights to the BCM2 module and code.
gregeast
Greg
Colorado, USA
2022 Taycan GTS
Cool, although that sounds more like a "sort of, with some work" than an easy "yes" 😎
chun
Taycan Turbo 2020, Cayman GT4
If someone gets around the coding part for the "fancy" animation, would definitely like to do it myself also.
Couldn't care less about the led logo, but the locking/unlocking animation i do like.
bigkraig
Los Angeles
Taycan Cross Turismo Turbo S, Huracan STO, Ferrari GTC4Lusso
i installed the euro lights and while i had it all opened i connected the LIN to test for animations. there are a few testing options in piwis that may activate it, none did. doesn’t mean its not possible but it wasn’t working when i tried
carrera356
carrera356
craig
LA
356, 991, Taycan
amazing. Thank you!!
when using the scan tool, is maintenance mode consider “spoiler position 5?” … I can adjust to that position but I don’t see an option for “maintenance mode.”
Cheers!
gnr3312
Austin
2024 Taycan 4S
Got mine today! Took about a month to come in from Lithuania, super well packaged. Now I’m debating it installing it myself or just ask the dealership to swap it out while they have it to replace the tires.
carrera356
carrera356
craig
LA
356, 991, Taycan
I was contemplating the same but I’m not sure my dealer will do it….
gnr3312
Austin
2024 Taycan 4S
Of course now I have to put everything back together 🤣
