Does the J1.2 have a Start Battery Heating feature?
hifi239
Will
I just learned that the ID4 has manual start battery preconditioning for charging. J1.2 also? Here’s hoping they will bring that to the OG Taycan.
chun
Taycan Turbo 2020, Cayman GT4
No such feature.
J1.2 has newer chemistry with a much wider temperature bracket that allows for ideal charging speed, so it’s not that necesarry anymore.
J1.1 could use that feature, sure. But it won’t come
SergeyIndy
Sergey
Indianapolis
@hifi239, I wonder why you think this feature is useful. I understand several other EVs have it. BMCe system manages the battery temperature behind the scenes. Pre-heating HV battery via a button is pointless use of energy that stresses the battery for no reason. Pre-heating is designed to heat the battery to optimal temperature to accept best charging rate to a point in time when DC charging will occur. Otherwise, there is no benefit of preheating the battery. I have been observing my battery temp and the car thinks that keeping it around 45F-50F is best for it when driving in outside temperatures between 25F-40F. I think well, it might be better for it to be heating above that to get more range, but I am pretty sure BMCe knows better than we do that energy spent will be more than the range benefit from doing so.
Therefore, I think the best thing is to trust the car to do its battery management and then when you really need to pre-heat then set charger as your destination or stop over as designed.
The only thing that I do not trust BMCe to do is manage battery temp with Battery Friendly off. Somehow, it allows the battery to heat to almost max 131F+ with no benefit whatsoever in getting you charged any faster to 85%. Therefore, I always have Battery Friendly On to keep the battery temp in no more than 110F and charging to 85% in the fastest time possible.
hifi239
hifi239
Will
Thank you for this. I understand. I was not aware that the car modulated the preconditioning depending on the SoC and charge plan. I thought when it was time for DCFC, it would try to get the battery to 110F the best it can ahead of time.
So anyway, first, I use Waze on CarPlay for navigation because of the live traffic/hazard/routing/police updates. The car will not run its own navigation and so will not auto-precondition when I run Waze. Maybe fixing that is what I’m asking for. My current solution is to disconnect CarPlay and run Waze on my phone only (ugh).
Second, even if I use Porsche nav, me and plugshare know charger reliability in a 300 mile radius better than Porsche - more than half the time a charger the car picks on a route isn’t the one I want for many different reasons. Navigating to my preferred charger requires gaming the logic and I have to spend many minutes fooling around making sure I have the right location and the minimum charge set right. I can’t do that while driving. I’d like an indicator that shows if preconditioning is on or off. I’d like button for a basic preheating for DCFC in 15 minutes to 85% from wherever the SoC is now please.
Third, I’d like to be able to turn off the preconditioning when I arrive at a station and the chargers are full or broken, and I need to move on. I think turning the car off and on does that but I have no way to tell.
SergeyIndy
Sergey
Indianapolis
@hifi239, these are very good points, so thank you for explaining. Then I agree with you that manual control of preheating would be useful with a target time point. The approach I used so I am not spending time finding chargers along the way, is to add them as Favorites. Then for preheating to occur, I just select the next one on the route from the Favorite list. I understand this does not help if PCM Nav is not running.
Johan Meert
Johan
Macan S, Taycan ST Turbo
You can always put the car in sport+, it will then heat battery to optimal condition for performance (and that is the same for charging).
