Drivers Seat Bolsters Always Adjusts on Entry
Brn2drive
USA - Virginia
2020 Taycan Turbo
I'm the new owner of a 2020 Taycan Turbo, amazing car!
Does anyone knows why the drivers seat bolsters and lumbar always adjust when I enter and turn on the car? I am the only driver of this car so the pre-set is always the same. Why does it un-adjust and then re-adjust every time? I would think that puts more wear on the moving parts of the seat.
chun
Taycan Turbo 2020, Cayman GT4
You have comfort entry on. When you turn off the car, the seat pulls back and the wheel lifts up to facilitate easier exit.
then when you turn the car on, it adjusts everything to previously saved position (seat and wheel)
tycanmt
Montana, USA
2021 Tycan 4S
Also worth noting perhaps that comfort entry can be turned off (somewhere deep down in the PCM menus).
Brn2drive
USA - Virginia
2020 Taycan Turbo
Comfort entry is set to off via the vehicle settings section in the PCM. The steering wheel and seat position do not move, which confirms its not using comfort entry. For some reason, just just the bolsters and lumbar adjust every time. I thought maybe its normal, but seems like others are not experiencing it. I even set all 3 presets as the same thinking it was defaulting to another preset...very odd.
