ciaranob
- Jul 3, 2021
- Houston, TX
- CT4S 2022 Mini Cooper S 2024 Electric in 2025/6
Yep this would definitely appear to be an issue i.e. not normal behaviour - either something is in constant comms with your car (app? if not key - assume you're main and spare key are in fact far enough away (min 3 m) when stored?) or there is a bug in the PCM that for some reason is keeping it in a state of readiness and not fully in sleep mode when locked/left alone.Below is an image I just took of my car sitting in my dark garage through the driver's window. Locked, armed and hasn't moved for 2 days. Key was inside. The picture is overexposed; it's not as bright as this looks but this gives you an idea. You can see the chrono clock is on as well.
