Front Cooling Fan Protection
skudinnit257
Anthony
Geneva, Illinois
2024 Porsche Taycan GTS
I have read several times about the front cooling (battery) fans getting damaged/blocked by road debris - does anyone know of an aftermarket solution to this in terms of some form of grate to install in the air intakes in the bumper?
gtm
George
Jacksonville, FL
Do a search for "Zun Sport".
AnloTaycan2022
Canada
Porsche Taycan Cross Turismo 4S
I had that issue and Porsche simply replaced them with the new version going on the J1.2 as they knew it was a real problem. Apparently the new fans are immune to this problem. This was done under my warranty at no cost. In fact this issue caused me a red electrical error screen! Thanks
hifi239
Will
The ZunSport meshes protect the radiators, not the fans. The debris that gets into the fan comes from the wheel well side. Updated fans and shrouds came out in a TSB around end of 2023. Recommended to check fan rotates freely every few months with a chop stick and the respective wheel turned all the way inward. If seized the car knows the fan isn’t spinning (err code) but inexplicably does not warn the owner!
targa666
Lies
the Netherlands
‘22 Taycan 4S sedan frozenberry, H-D sportster 883 low
Learn something new every day!
