Hankook tires
jeffb
Jeff
Washington, DC
2025 Taycan 4S
My new Tacan 4S has Hankook tires. I was hoping for Pirelli or Michelin. What experience have others had with Hankook tires on their Taycan? Handling? Noise? Wear?
Jaymo
Jason
Florida
Had Michelins on my 2020, and have the Hankooks on my 25, very impressed so far, have 3k miles.
Quiet, good handling, and so far so good...
Murph7355
Andy
Car came with Goodyears.
Has Hankook now. Much, much better.
Briguy
Brian
Toronto
2020 Taycan4s, 2025 Mercedes SL63 AMG, 1973 911
You are fortunate, IMO. My experience with Hankook is on winters. they are exceptional.
WedmoreBlue
Worcestershire
2023 Taycan Sport Turismo
I bought a set of Hankook’s winter tyres last year as the Pirelli’s fitted from factory suffered badly with the Ackerman Effect in cold weather … vast improvement & when the Pirelli’s need replacing I’ll researching the Hankook equivalent
jvdsanden
Jos
Uden, The Netherlands
www.BMK-inkoop.com
Tesla Model S75D, Taycan CT4S and Tesla M3 oreon
I hope you have the ION version because they are specially made for EV's.
Jhaas911
2021 Porsche Taycan 4 Coss Turismo
I like mine. 2021 CT4.
SergeyIndy
Sergey
Indianapolis
I drove a 2025 RWD with 21-inch all season Hankooks for a day and they were exceptional in all of the above. I wish we could get them on a pre-facelift models, but that is not possible.
Vercingetorix
The O. C.
Don’t seem to very good in the rain. From Tirerack:
Not every tire in this test has been specifically built for EVs, but the iON evo AS, from the very composition of its compound to the sound-minimizing patterns molded into its grooves, is dedicated to serving as an electric vehicle tire. It was a bit mixed in practical application on the road, handling big hits well but failing to dampen smaller cracks and undulations, resulting in noticeable up-and-down movement. Noise too, was low volume over smooth surfaces and blended tones nicely, with only minor pitter patter or wind noises muted but noticeable. Even concrete noise only rose to moderate levels with a slightly higher pitch but without any strong resonant sound. The steering was nicely weighted once it was spurred into action, only suffering from some lethargy immediately off-center that made it feel momentarily behind the driver. With 263 Wh/mi, the iON evo AS was handily the most efficient tire tested.
In wet testing, the steering felt lighter, with less weight behind it than on-road, though it remained accurate and precise. Properly separating inputs and not trying to force braking or throttle during turns was important to keep it from drifting away or stepping out, which could be a concern for unprepared drivers during emergency situations. The lower overall traction also required a bit more lead time for braking, leaving little margin for error anywhere. On drier surfaces, most of those issues evaporated along with the water, and the iON evo AS showcased some genuine athleticism and solid braking and was significantly more forgiving.
Johan Meert
Johan
Macan S, Taycan ST Turbo
My '25 came with a set of 20" winter Pirelli and a 21" summer set with Hankooks. Obviously will have to wait until spring to test them.
ze_shark
JC
Southern Malaysia
https://www.taycanforum.com/forum/t...lar-tires-test-comparison-by-tire-rack.20406/
and the related video
Caveat: not Taycan dimensions.
But still illustrates how there is no free lunch in tire matters, and the massive differences in braking distance and lateral force there is between performance summer tires and EV/all season tires. 10 to 12 ft at only 50 mph.
Hankook ION EV AS is the best in consumption/rolling resistance, but way behind a PS4Sor PZ4. It can make all the difference between a close call and an accident.
