- Adrian
- Jan 11, 2021
- Aberdeen, Scotland
- 992.2, ex GTS ST & 4S owner, Macan T
It's a real heat pump as it is at extra cost in some markets where it is felt it is not needed.Many thanks. That gives me piece of mind.
1) I had a tech tell me yesterday to look at fuse connection. If you only see one metal contact it is the best way to know it is a non-utilized fuse position.
2) I am awaiting a new HV Heater from Germany (just shipped). With many discussions about "the heat pump" I have looked for some explanation of how the heating system operates. Most of the "newsroom.porsche" articles discuss heating in an abstract manner.
The most understandable description I have found was in an article in Porsche Excellence Magazine online (look under subheading "Cooling"
https://www.excellence-mag.com/issues/269/articles/all-electric-taycan-tech
Excerpt:
"Because the waste heat from the coolant returning from the motor/inverter cooling circuit is insufficient for rapid cabin heating and window defrosting, a third, high-temperature cooling circuit is used. This third system uses a small high-voltage electric heater grid to provide cabin heating and defrosting as necessary by circulating heated coolant through a heater core inside the HVAC box. The high-temperature coolant circuit is also used to “pre-condition” the battery pack for charging by heating it up to the optimum temperature for lithium-ion battery charging, which is about 86 degrees Fahrenheit."
It remains a mystery to me whether the "Heat Pump" is a true heat pump or part of a waste heat coolant pumping circuit.
Interesting re the pre-condition comment - my battery has rarely if ever been that temperature (30C) and never when charging at home. Perhaps this relates to DC charging rather than typically home based AC charging.
