69Mach390
- Nov 14, 2025
- Florida
- 24 Taycan 4S
It may not make sense, but I trust the data from the tire manufacturers.i'm speaking from engineering background and personal experience. saying grippier tires have less rolling resistance does not make sense. everything about them from tire temp, grip, and increased wear indicate the opposite of what you're linking. and lines up exactly with OPs experience.
have you ever switched to summer tires and gotten better fuel efficiency?
There are also plenty of independent studies and actual tire ratings that show the same data:
Summer tires tend to have less rolling resistance vs all seasons or winter tires.
That said, there is so much more involved in tire design than just “summer vs winter.”
I’m speaking in generalities based on the tests and data from the links I posted above from tire manufacturers.
They can design tires for different things, including rolling resistance.
For example, here is a test of a lot of all seasons tires and rolling resistance. A pretty significant difference between the best and worst-
https://www.consumerreports.org/car...tires-can-save-you-money-at-pump-a1547901110/
