- Jul 30, 2021
- WA, USA
- 2023 Taycan TCT, 2024 Q8 eTron P+
I think you underestimated the interest/rent charge. Interest amount you pay every month varies every month as you pay off your cap cost (the interest on the residual stays constant). Most calculators just use the average interest/rent charge, but that only holds true if you pay your lease all the way to the end. If you terminate early, they calculate actual interest to give you the payout amount. A quick calculation given the numbers you provided, the first 3 months of interest + 9.5% tax would be:I ran a 39/10k $0 Down (just inception fees due) lease for a $190k MSRP Taycan Turbo (right at MRM) using a calculator. Buy-Rate is 0.0034; I did 0.0038 to account for a slight mark-up (max a dealer could do right now is 0.0042, so 80 basis points). You multiply the decimal by 2,400 to convert it to an APR.
Monthly Payment with 9.5% LA tax is $3,784--$1,037 of which is interest/rent charge. So, you're right: 3 months of that + Acq Fee, and you're right around $4k in costs, so $3k-ish in savings. Probably not worth the effort.
If someone is purchasing a RWD/CT4 or even a 4S/GTS, it could be worth taking advantage of the loophole, depending on how much energy you have. I ran a similar lease structure for a $140k MSRP Taycan 4S, and ~$700 of the monthly payment was rent charge.
Month 1: $1519
Month 2: $1501
Month 3: $1482
(the above is essentially interest [2*MF] on 190K - $7.5K rebate - what you paid off to date, then add 9.5% tax)
That's ~$4500 in just interest and taxes on that interest in 3 months. Add $1200 inception fees + 9.5% tax on those, and this lease exercise is costing you $5,816 in order to save $7,500. One extra payment and you about break even. Then you risk the clawback if the current administration gets their way.
Now, if you could put $189,960 down, make the residual $1, then it would be worth while, but I doubt they would let you do this. I have done one lease once with $0 down but a $150 residual (the lowest the finance computer system accepted), which confused the crap out of the finance manager at first, but after we ran the numbers he realized that it was way worth it (the lease had a subsidized interest rate, so 39 lease payments + $150 buyout was way cheaper than 39 loan payments). When I tried doing it again few years later, it was no longer allowed - finance instituted maximum down and minimum residual for leases.
