Lost connection to apple music/spotify via PCM
Maximilian
Maximilian
Maximilian
Austria
Porsche Taycan Cross Turismo
I home someone from Porsche reads our Forum?
Hi,
Has anyone experienced something similar: after software update or possibly after weak data reception PCM has lost connection to Apple music/spotify. Icons are grayed out and if you press on them, u get this message:
any idea how to fix it? Tried to link accounts via my porsche but didnt help (status shows linked)
Any idea how to fix it?
Yep me too. I'm sure it will sort itself out.
MarkR
Mark
Taycan 4CT
I have the same problem. Spotify not able to log in. I have reverted to using Android Auto, but not happy about that as the sound quality is not as good.
I also find that the installed Spotify drops out regularly when I am using it. It jumps to Android Auto and I have to press play to get it to play again. When I do this, it then jumps back to Spotify....this happens several times per journey. I had Spotify in my previous X5, and it worked flawlessly. I will definitely be raising this issue the first time it goes to the dealership.
SergeyIndy
Sergey
Indianapolis
Same here. Spotify icon has been greyed out in the PCM. Android user.
Hirschaj
Jim
Austin TX
This is most likely because of your audio quality settings in the Spotify mobile app. Go change them to the settings below and I bet you will notice a huge improvement in the quality when you’re on Android Auto.
Porsche Taycan Lost connection to apple music/spotify via PCM IMG_1326
Porsche Taycan Lost connection to apple music/spotify via PCM IMG_1325
MarkR
Mark
Taycan 4CT
Thanks @Hirschaj . I will take a look. I do recall looking into this previously, but I cannot recall what I changed now. I think it may have been the equaliser, so will check these settings as well. ?
*Edit, I saw that both were set to automatic, so I have changed to "very high". Will see what it sounds like in the morning when I head out. Thanks again.
MrBlueSky
Mark
Northern Ireland
Taycan CT 4S
It looks like I have Apple Music and Spotify working again. When I tried to open them this morning, Apple Music presented me with a QR code and I was able to login again. Spotify also opened ok.
I had been working on my Bluetooth connection before all of this as my phone wasn’t connected/wouldn’t connect to the car. Not sure if there’s a link?
Anyway, it looks like things are back to normal………for now ;)
Rossmeldr
Ross
Uk
Taycan 4s sport tourismo
Also back to normal this morning for me. Not sure if it’s related, but also had an infotainment software update as soon as I got into the car this morning. Spotify connected as soon as this update completed.
Maximilian
Maximilian
Maximilian
Austria
All services are working again now
SpawnyWhippet
Andy
San Francisco Bay Area
2023 Rivian R1T, 2020 Taycan 4S, 2016 McLaren 570S
I had this issue (greyed out Spotify, unable to use remote services etc) for the last couple of weeks, then noticed my LTE was not working. Tried pulling fuses without success. In the end I pulled the 12V battery terminal and HV disconnect under the hood, let it sit for 15 mins then reconnected. All works fine now. I had a few warnings about brake pedal position after the reconnect, but when you hold the brake pedal it recalibrates itself.
Surley 12v battery disconnect only and not HV (that would be dangerous if possible)?
Recommended to disconnect for no more than 5 mins to avoid issues like the brake pedal.
Glad that your problem was resolved.
SpawnyWhippet
Andy
Disconnecting the 12V does not power down the car, it is kept alive by the HV DC-DC system. No danger whatsoever disconnecting the HV, its a simple green connector near the 12V battery specifically designed to drop the HV contactors to make the car safe to work on. You could lick it and be just fine.
Ok didn't realise that but as the relevant systems are 12v only there should be no need to go near the HV connectors.
