Magnetic Phone Charger Idea: Need 3D Engineering & Printing Help!
RED!
RED!
Stu
Toronto
'24 ST GTS, 996 GT2, 87 Turbo Cup car, 04 NSX
I like this idea, but I'd like the phone to sit on its side vs. flat, so its easy to snap into place
d00d
4MB, HYA
yes
If you don't want to overheat your phone, and won't be looking at it, why not just throw it in the center console away from the inductive pad?
RED!
RED!
Stu
Toronto
The center console box isn’t as convenient as snapping it in a charger at my knee. Also it can still get hot in the console since it’s an enclosed space
wilho
Finland, Oulu
Boxster 986, Taycan GTS ST, iX1
AutoX
LA
Taycan RWD, Model Y, MachE
just use double sided tape/mounting tape on an apple magsafe charger and put it anywhere you want. It would also be super easy to make a 3d print block with a hole cut out to fit the magsafe puck.
RED!
RED!
Stu
Toronto
Hi,
this is easy and nice solution, I'm using it without the flexible gooseneck arm, but with Quadlock charging head. Costs a bit but really no-hassle solution.
https://www.quadlockcase.eu/collections/shop-mounts/products/car-cup-holder-mount
https://www.quadlockcase.eu/product...selected=eyJvcHRpb24xIjoiUUxILU1BRy1XQ0gtMiJ9
you can run a 50cm usb C-cable from the arm rest storage box
OF COURSE: you'd lose one of the cupholders
The whole idea is to cover the mouth of the useless lower dash storage bin, I like having two cupholders and don't want to sacrifice
RED!
RED!
Stu
Toronto
AutoX
LA
I need power to it for Apple CarPlay since it eats power, also, I'm hoping to locate it in the useless space, yours is a little harder to reach IMO
replace the head with one that is powered. the base is a standard ball that will accept most most magsafe head like this one.
https://www.amazon.com/LISEN-Strongest-Wireless-Universal-Magnetic/dp/B0CG6P9F36/ref=sr_1_4_pp?crid=YXERROM9BYFB&dib=eyJ2IjoiMSJ9.jTK2avSUqAbUY2W-sjCQQRloUD9_MBHUH2WxU2VrMBj58d4pGTffga98Fw1TJjO7qs2OkSUM1bsQSG5TgFsLcSg4yt2WNZCA7Ehn9TTgflCgKhcDohgcNk-EezUQLzQnL9DBTigwzMF6iJHSt8cYvgIj1U8tztujOBVg8x8zi9b7wJyUyTXpgbtrhNHUtn2xF6u3V_yC_LUf6UwxuaE6VaAswvWEwQDvSBGgeMrQVLg.2HlbbpOgEZnCQUfqW1OUQhZNibPx5eInoQ4TcsXLCIU&dib_tag=se&keywords=magsafe+car+mount&qid=1771452755&sprefix=magsafe+car,aps,311&sr=8-4
or this one.
https://www.amazon.com/dp/B0CQPHLQY...=d2lkZ2V0TmFtZT1zcF9kZXRhaWxfdGhlbWF0aWM&th=1
there is access to the fusebox on the driver left leg it that you can easily tap into and easily hide the wire in the weather strip.
