New toy to make washing easier
ShiftyWolf
Central Florida
Nice to see another paint can collector as well
j.w.s
Jeff
San Francisco, CA USA
My old power washer was dying .. just setup a new one. Will try it this evening when the sun has moved.
Since you may have just started down the rabbit-hole of the wall-mounted and ready to go pressure washer world, I highly recommend three things, if you don't already have them:
1) A de-ionizing system like https://crspotless.com/products/diw-20-high-output-wall-mounted for "spot-free" rinsing. It's glorious.
2) A "foam cannon" for applying car wash soap.
3) A powerful cordless "leaf blower" to speed up drying. Like: https://www.makitatools.com/products/details/GBU01M1
Your car is white, it seems, so the different won't be as dramatic as it would be on say a Black car, but having used all of the above for many years, I am never going back to the old days. I can wash, rinse, and dry a car in five minutes if I rush it. Fifteen minutes if not. And without touching/rubbing anything.
Uknown
Uknown
Sam
US
Taycan 4S MY20
2) A "foam cannon" for applying car wash shop.
Item 1 looks interesting!!
Item 2 I have but am going to update it as I don’t like my harbor freight version and the little one that came with the wall mounted unit is tiny ..
item 3 brilliant idea! I will add something like this.
Thanks
j.w.s
Jeff
Thanks
There are quite a few "good" foam cannons, but even more bad ones - including most of those that come for free with inexpensive pressure washers.
I started out with one of the cheap ones, which I liked, but switching to a good one was a revelation. I use: https://www.amazon.com/MJJC-Thicker-Technology-Connector-Pressure/dp/B0CYY3YZGD/
You of course get the best foam cannon results when using a wash soap that says it was made for foam cannons. Again there are plenty of good brands.
RAHRCR
Northeast, US
Taycan Cross Turismo 4S
I am way down the rabbit hole on detailing….although admittedly, I enjoy rinseless washing more than the pressure washer these days. That said, a wall mounted setup with a hose reel and DI water is convenient when you want to go that route.
Porsche Taycan New toy to make washing easier IMG_5208
Uknown
Uknown
Sam
US
Taycan 4S MY20
Can you share which wall mounted unit that is?
It is about as good as a cheap big box store washer with 100ft of hose.
https://a.co/d/f3qhgwn
I have no real complaints so far as it is way better than dragging a big box store washer around the car and then putting it all away. Power is enough for the car.
I wouldn’t say it is amazing. But I am happy with it after initial use.
Ok, so now I'm envious!
I hate my Karcher with a passion - it has the world's most tangliest hose ever (and that's the anti-tangle one).
Never knew this was a thing and will now look into getting one!
lemans
United States
Cayenne Coupe, Camaro ZL1,
Nice setup there!
