Murph7355
- Andy
- Feb 1, 2022
- UK
- GTS ST; TVR Griffith 500; Caterham 7; Volvo XC90
Is the US like the UK in that the connectors are built to a standard? The brand shouldn't matter, but compliance with the standard does.
And everything in the chain needs to be protected to the right level otherwise major issues can happen. Breakers, cable, sockets etc etc all designed to make sure any "failure" doesn't lead to a fire.
I had a 32A "commando socket" installed by my electricians on Wednesday. Every last element was checked carefully, specs calculated, install tested and certified.
Looking at the melted socket above, is that on a trailing lead? And does it have a cover? Am assuming the grey cable is the supply - is the housing on that end cracked away from the socket part?
The socket installed in my garage is wall mounted and has a cover that flicks shut to prevent dirt ingress. The cable also cannot be released until the power is isolated at the socket.
(I'll post back up on here if my garage sets alight due to the charger ).
