Porsche Connect..no connect!
Hami
Hamid
San Diego
Taycan Turbo S
The most difficult part is taking off the brackets that keep the fuses locked in. There is a release clip on one side that you press and pull out but you'll need two hands. In the US version, A11 is the top set of fuses with the last one near the pedal. C1 is the bottom row with the fuse nearest the door. Both need to be taken out. Good luck, it s a tremendous achievement when you get it to work! Way to go German engineering let's make things as complicated as possible! :)
FrankV
Netherlands
Taycan ST MY25
Giving it a try at this moment. Pulled the fuses and waiting patiently ?. Did you lock the car in between, left it unlocked for now. Fingers crossed this works, otherwise I’ll need to plan an appointment at the dealership.
Hami
Hamid
San Diego
Taycan Turbo S
Left it locked for 30 minutes.
