Preconditioning before charging - is mine working properly?
Maxzor
Netherlands
Basically my question comes down to 'is it working as it is supposed to be working'?
I use the navigation to a known Ionity (250kw) charger, the battery temp starts with 11c, the drive is 10 min. I put the car in S and did some (10min) spirited driving. I arrived with a battery temp of 16c, charging for the first 10 min was still slow.
Is this normal behaviour or is the car not pre-heating the battery?
Sounds quite normal to me. 10 minuter driving is a bit short time to achieve much more. Consider that the battery has a mass of about 700 kgs, so more time is needed. It would require quite a lot of power in the heater to raise 700 kg mass.
YLA G
Yves
Mini Countryman, Tesla P3D - Order: Taycan ST
10 min drive from this weather is normal.. that's nothing even in my Tesla
gusone
gus
South East London
BMW Series 3 XDRIVE M SPORT
D
Also do a hot pre heat/cold cool an hour before. That will add another 5*c
Maxzor
Maxzor
Netherlands
Great, thanks for the explaining, maybe I was expecting to much of it ;)
Also thanks for the pre heat/cool tip!
JRNJTAYCAN
Joe
NJ
22 Ferrari, 22 Q5, 2015 Titan, 2015 Wrangler
What you are seeing is very normal! I have the same short commute to my EA charging and had the same issue. What I do now is plan errands before heading to the charger. I leave my house with setting the charger in the Nav. system then get the car wash, stop for a coffee etc. then head the charger. This adds maybe 15-20 extra mins which gets my battery temps up closer to the high 90 - 100F mark.
It's just more time for me to enjoy cruising in the car before charging.
jetbox
Scotland
Yes
Sounds completely normal as above. You need 20-30 mins to go to the charge destination for it to preheat the battery.
just a personal observation though. I actively switch off the nav to stop the car preheating the battery as it’s a huge consumer of power( which then eats range) all for what, just a few minutes shorter charge time.
charge times are plenty quick enough anyway for me
