Taycan jack point ocation? Is there one? Jack Stand location?
Pjjameso
Paul
Great Falls
‘20 Taycan Turbo
Okay, stepped back and noticed my wheels were put on wrong by the guys that applied the ceramic coating. Need to switch left and right front wheels. Was planning on doing this myself but didnt realize that there doesnt appear to be a jack for the car. Is this correct or am i blind as to where it is stowed.
If there isnt one, i have a jack and two jack stands but how does one go about swapping the tires as i dont see a good spot to place the jack stands?
Tincan
Seattle
CT4
Did you get anywhere with this? I have a similar issue, and also have a floor jack + 2 stands :/
I don't see any jack points near the middle that would allow to lift both sides high enough to place the jack stands. The manual only shows 4, on each corner of the car.
Is there a way to do this without a lift (like quickjack referenced in the linked post)?
Mind that you will also need to deactivate the air suspension before jacking (PCM - additional chassis settings).
kort
'23 Lucid Air GT
a very important step in the process, thanks for the reminder
tbinmd
Maryland
CT4, 991.2 GT3
I have a set of jackpoint jack stands that allow you to put the car on a jack stand @ the jack point. Don't have the Taycan yet, but don't see an issue with using them for it.
http://www.jackpointjackstands.com
