Using both handles on a single station?
DerekS
Derek
Los Gatos, CA
2025 Taycan GTS
I pulled up to an EA station yesterday, one of the connections on it was in use by an E-Tron. I grabbed the other one and the gentleman using it told me only one works at a time on each "pump."
Is that accurate? If so, why do they have two cables (same connection type) on one pump?
TurboBear
Mid-Atlantic
Taycan RWD
"If one connector on a charger is already plugged into a vehicle, can I use the other one?
Though there are two connectors at each Electrify America charger, only one can be used at a time. Having two connectors ensures that it’s easy for you to plug in—no matter where your car’s charging port is located. If either connector is in use, look for the next nearest charger. Most charging stations have at least four chargers to increase availability."
Source: https://www.electrifyamerica.com/mobile-faq/
