- David
- Jan 28, 2019
- Santa Cruz
the PMC+/PMCC are not very good EVSE’s for the North American market - they are expensive, physically large, heavy, temperamental, and the 10-gauge wire porsche ships for the 50/40 amp plugs is only barely safe and gets quite hot during normal usage (8 gauge wire would’ve been a better choice)
Porsche’s in car software for charging is:
Well most J-1772 chargers that can dynamically change their current/load start low and ramp up over time - when Porsche “samples” the current it only pulls power for a short while and then shutdowns once it has sampled the possible current - and then waits to start charging at the last minute - well if the current changes over time this calculation will be wrong…
porsche could easily solve the problem by having charging support for:
Porsche’s charging infrastructure is not world class and their external EVSE’s are not that great- but they sure do charge a lot for them vs. compeition.
- is too complex for normal humans to figure out
- not very robust in the face of changing amperage from the J-1772 specification
- ##% battery charge target
- only between these hours x & y
