Ipercool
- Paolo
- Nov 13, 2022
- Italy
- 23 Taycan GTS ST - 22 BMW i3S - 18 MINI Countryman
- #1
After three years, I moved from a J1.I GTS ST to a J1.II Turbo CT on October 25th.
The lease was about to expire, and instead of buying the GTS, I returned it and took advantage of this Turbo, which was available for immediate delivery at a very significant discount.
I also did this because it restarts all the warranties and also leaves the ownership tax free (in Italy, for the moment, the ownership tax for BEVs starts after the fifth year).
I had never considered buying a CT, but I have to admit that its particular characteristics make it very suitable for the use I make of it.
The specifications of the Turbo seemed excellent to me, and it resembles a Taycan quite well, which I could have specified.
I've driven the first 1,000 km and am very satisfied. They are two different cars; the Turbo has almost 300 more hp, which you can feel, but it's less extreme than the GTS.
The GTS' suspension setup is different; it's more performance-oriented, while the Turbo is more docile and more of a touring car, but it's obviously very fast.
On the first home charge, it predicted 414 km of range; the GTS never got close to 360 km.
The base height in "Normal" mode is different; the GTS is lower. I prefer the Turbo's setup; being a little taller, the proportions between height and length seem more harmonious.
The Turbo has an 11kW charger, while the GTS had a 22kW one, so charging at home is slower. But considering that the GTS's 22kW unit broke for me, as it has for many others, I hope this one is more reliable.
In any case, I really like the Taycam—every Taycan—and I'm happy to have them.
Among other things, there are few charging stations here, but there are very few BEVs, so paradoxically, the charging-to-vehicle ratio is quite good.
I'll give you more impressions in a few thousand kilometers.
Ciao from Italy.
Ciao from Italy.
