4S - Is all wheel drive better then rear wheel drive
69Mach390
Florida
24 Taycan 4S
OP asked for a simple input. This is my subjective evaluation after 3.5 years of ownership and many loaners & test drives:
For the OP, maybe add a line for “Colorado traction in the winter?”
JerryLNK
Jerry
Lincoln
22 TAYCAN, 25 718 Boxster GTS 4.0, 24 Cayenne
@jkolorado - Your question has led to a great discussion, no surprise. This forum is my go-to for research. But then a decision has to be made. Not sure if you have made a decision yet as I haven't read every thread. However, I live in Nebraska and head to the Rocky Mountains frequently. While I drive my 22 RWD to the mountains in the summer, I drive the Cayenne in winter months. However, if I lived in Denver area, like you, then I would get a 4S and use Nokian Hakkapeliitta winter tires for mountain driving for skiing, snowshoeing, hiking, etc.
Happiest of journeys to you and everyone in this stellar community!
69Mach390
Florida
24 Taycan 4S
Thought that part is obvious was trying to clarify other controversial areas.
If he’s asking the question still, it’s probably not obvious to him.
Plus plenty here still pitching RWD as being suitable for snow. I’m in Florida, so my experience is only theoretical. 🤷‍♂️
prj
Estonia
www.mapev.net
Taycan CT 4 - 2026
On winter tyres you can very much drive a RWD car in the winter and snow without problems, but it's just not a fun time, and the Taycan is supposed to be a fun car.
Manni
Austria
Porsche Taycan Sport Turismo RWD
Hallo, wie hoch ist die Rekuperation beim Taycan RWD im Vergleich zum AWD .
Gibt es dazu Unterlagen von Porsche ??
Ich höre regelmäßig meine vorderen Bremsen bei der normalen Rekuperation.
Außerdem hat der RWd an den vorderen Bremsen einen höheren Verschleiß.
Ich habe in Deutsch geschrieben.
Danke
Avantgarde
Eugene
Ann Arbor, MI
I owned multiple BMWs and RWD porsches over time.
RWD BMWs are pretty much undriveable with snow on the ground even in flat geographies. I got stranded multiple times, in all odd and unexpected ways, until I started regularly using winter tires, which transforms the car.
I find Taycan RWD a lot more acceptable in Chicago winters with the conti-all seasons. Weight on rear wheels make quite a difference. Still feels like I always need to be extra careful but then main concern is braking not traction. For someone who is willing to do the snow tire swap in winters (which in the US most people don't) 4S could bring significant additional capability from traction perspective. Otherwise feels like braking will be your main bottle neck.
69Mach390
Florida
24 Taycan 4S
It seems that rwd + winter tires is doable.
But AWD + winter tires is still much better.
If you have the option of AWD and can afford it, I see no good reason to not check that box.
AutoX
LA
Taycan RWD, Model Y, MachE
Just go test drive both. If the power in the RWD is enough, and you want to save a few $$, then get the RWD, otherwise get the 4S. I think you'll find the the driving dynamics will be very similar between the two on PUBLIC roads.
I have a MachE GTPE and and Tesla MYP (0-60 in 3.5 range. Faster than a 4S), both are much quicker than the my RWD, but I realize that that I rarely do 0-60 sprints after the first week, and all that power was wasted. The RWD has plenty of passing power even at highway speed. I would describe it as zippy, but not blazingly fast. Another 100hp would be perfect.
69Mach390
Florida
24 Taycan 4S
Sounds like a MapEV tune is in your future.
Flying ace
SF CA
GTS ST, 997.1 GT3, 991.1 GT3
Ultimately, it comes down to your experience driving in the snow and your use of the car in the winter. If this is a daily car that you must take out in the snow, I recommend a 4/4S.
I recently took my GTS (also AWD) in 2 feet of snow on dedicated snow tires. This was probably the most confident winter drive I had despite owning the follow AWD vehicles (albeit on all-season): Lancer Evolution 8, E70 X5, G05 X5. Yeah, the AWD system of the Taycan is that good, much more responsive than any mechanical diff, and probably the weight of the car and the fat 285 contact patch of the snow tire helped alot.
69Mach390
Florida
24 Taycan 4S
Hmm, I’m not sure about that.
Where I’m from, 3.1 to 3.4 is faster than 3.5.
I had a Mach E GTPE for 4 years. The 4S is faster to 60. And after 60 it’s not remotely close.
If it was a 2024+ Mach E GT, different story. That’s faster to 60 and ties 1/4 mile for a 4S 2020-2024. But right about at the 1/4 mile, the 4S trap speed is significantly higher. So while it’s playing “catch up” that whole race, anything past that it would crush the Mach E.
And of course a 2025+ 4S is significantly faster.
kern417
Cincinnati, OH
2021 Taycan RWD
I'm (still) in that same boat, and that's the main difference. 3500lb RWD is way different than >5500lbs. In this car I have yet to feel it lacking, but this upcoming week may be a test if I'm feeling ambitious.
To your point a bout BMWs getting stuck in weird ways - mine drove around town just fine on the michelin all-seasons in some light snow. The only time I ever got stuck? Back home, Trying to get up my driveway 🙃
Sly_North
Swiss/Zurich
2022 Taycan ST PB+
The Canadian trick for RWD: winter tires (compulsory, whatever the car is), a big bag of sand in the trunk, and all's fine ;)
