- Frank
- Aug 19, 2021
- Oxfordshire, UK
- Taycan CT4S, Ferrari 355, Merc 500E, Prius PHV
It is simply that whilst the actual thrust at the tyre depends on the torque at the hub that actually depends on gear ratio too so torque actually falls out in the calculation since it is actually power that counts.I think this is where I am getting tripped up. In our race cars we always tuned for max power even at the expense of torque. But for our street cars we always wanted max torque under the curve as it was much more fun at street speeds and RPMs.
Can you explain why having the extra torque, all other things being equal, doesn't really matter on the street in an EV.
With an IC engine and a multi ratio gearbox having a lower down torque peak means more power at lower rpm which means less gear changing which is more relaxing (but slower) so easier to drive.
A a simple example of what I mean imagine two theoretical IC engines. The first produces twice the torque of the second but at half the rpm. That is the same peak power.
At the road speed for peak torque the first engine will need double gear reduction to match engine to that speed as the second engine. That means the thrust at the tyre will be exactly the same for both engines because they have equal power despite one having double the torque.
The first engine will maybe feel easier and more convenient to drive but no quicker.
It is always the available power at that engine speed that is actually important but it is torque which is used to calculate it.
I think it is a marketing thing which grew from selling cars with engines which weren’t all that powerful!
