AndiL
- Andreas
- Apr 14, 2021
- Germany
- Taycan 4S, ID. 3
This is correct. The system (hardware!) can only (safely) store 1 charging certificate, to remove it the PCM has to be reset. The ISO15118-2 standard also doesn't contain support for multiple contracts, this will be coming with ISO15118-20 (which also is incompatible to ISO15118-2! so EVs need both installed).to my knowledge Taycan only supports a single vendor for plug&charge - no plug&charge support for multiple networks at this time - I'm hoping a software update can address/improve this limitation
I welcome correction - I'm hoping @AndiL might be able to help with factual information.
Update: Just to make sure this is clear, you CAN use other charging providers with the Taycan and Plug & Charge. The Taycan is NOT locked to the Porsche charging service.
