- Adrian
- Jan 11, 2021
- Aberdeen, Scotland
- 992.2, ex GTS ST & 4S owner, Macan T
Profiles, timers and Direct Charging are only relevant for AC charging.I am a relatively new Taycan 4S owner (3500 miles). So far, the car has been great with the exception of some of the known issues I have read about (back up camera, PCM wackiness, etc). I recently took the car on a round trip from Phoenix to Indian Wells, CA stopping for a charge at EA in Quartzite (which was totally seamless). When I got the car home last week, I plugged it in for charge overnight (Home profile to 85% at optimized charging). When I went to drive it on Tuesday morning, I got the following:
I thought it was just an anomaly, drove to work, spent lunch charging at the Wal Mart EA station with no issue other than the SOC when at 85% was about 180 miles (before the road trip it had been 200-ish miles). Plugged it in on Thursday using the same profile as mentioned above and got the following:
Did a little research and saw it was suggested to switch off optimized charging and move to a timed charge. Switched this in the existing profile, plugged it in and received yet another error message. I pressed Direct Charging in the car and it started charging with no error although I had to manage it up to 85%.
The other steps I have taken are to delete the profile, turn off and lock the car, wait 5 minutes, turn it back on and create a new profile - same charging error result. So, it charges on EA. It charges on Direct Charging, but throws off the error every time I try to use a profile at home. The dealer just wanted me to schedule an appointment (3 weeks from now). I wanted to see if anyone else had seen this error and if there was a fix
Could be heat issue, failing AC charger (charger is in the car and not the wall box) or earthing of your wall box.
Ensure no charging control is enabled in your wall box / EVSE to avoid conflict with the car controlling the charging session.
