Heating Failure
Hirschaj
Jim
Austin TX
Some of them. I have a pre 2/14/23 heater but my Taycan has not been a subject of this recall, at least yet.
Same here.
My heater is pre-2023, also. Too many bad heaters for Porsche to recall at once, so they are adding cars to the recall bit by bit. I hope that my Taycan heater gets recalled before it fails again.
Ross
Ross
Lancashire
Taycan GTS - Audi Etron
HEATER UPDATE
Excellent service from my dealer. Rang them yesterday (forgot Monday)
I am going on holiday tomorrow for 2 weeks and they are taking my
car in and doing it while I am away.
(no loaner needed and probably not one available at such short notice but still good service)
They have the part in stock unsurprisingly.........
Interestingly they say my car also is scheduled for 4 updates which they will do including
a software update to the heater to apparently help prevent them failing.
Donar
Netherlands
Taycan ST ‘22 - Polestar 2 Performance '20
My heather failed again 1,5 years after it was replaced. Back then the dealer already confirmed that it was replaced with the same part so most likely it would fail again. Now 1,5 years and 40k kms later it did. My car will be picked up by Porsche Assistance later today. Hope they fix it quickly.
AceArora
Sanj
Porsche Taycan & Audi E-Tron
New member of the failed heater club. Mine failed yesterday. Can anyone confirm if UK has same warranty as US for heaters? Apparently US gets 6 year warranty on heater from new. Thanks in advance.
6 years?
3 is the norm and should already have been replaced as part of a recall campaign where in which case if it had failed your warranty should still cover.
Consult your OPC.
AceArora
Sanj
6 years?
Consult your OPC.
What was the recall campaign for the heater called? This way I can check when it was done.
There are many posts and threads on this forum about Taycan heater recall, including links to Porsche TSBs about it. Search is your friend ;-).
Two recalls, two different campaigns
WPL8 - https://www.taycanforum.com/forum/threads/heater-broken-my-turn.13788/page-21#post-303104
WSL3 - https://www.taycanforum.com/forum/t...assenger-compartment-heater-sep-2-2025.30306/
and you can try your luck here to check your VIN - https://recall.porsche.com/prod/pag/vinrecalllookup_V3.nsf/VIN?ReadForm&c=greatbritain
AceArora
Sanj
WSL3 - https://www.taycanforum.com/forum/threads/tsb-wsl3-–-replacing-electric-passenger-compartment-heater-sep-2-2025.30306/
Thank you mate. I have AA warranty rather than Porsche so lets hope it works out. Thanks for your time.
