Nickj
- Nick
- Jun 29, 2020
- UK
- Crayon 4s
Just wondering if any solution was found. OI had been working fine for 6 months or so but now either doesn’t start or overruns, and I end up with no charge or being charged peak rate, as it hasn’t charged in it’s generated window. Spoke to octopus and have a case raised but no solutions yet. I have a pod point set to manual with no timers, no timers/ profiles set in car ( unless OI creates encodes), and last 4-6 weeks has been proper random. Can’t rely on it at all. Charging plan created ok, just doesn’t stick to it!
removed car and reinstalled as octopus advised, made no difference.
Understand I could make everything dumb but even when I do this the OI kicks in and buggers things up. Only way to stop it controlling the car is clear profiles/ timers, put it in privacy mode and use a timer on the podpoint. Right pain.
Really want to use OI as benefits the house rate and also if I need more than 6 hours it charges the whole battery all at the cheap rate.
Any ideas appreciated.
