Latest Nav Preferred Charging Operator settings
Dabz
J1.1 4S
Had my J1.1 updated today and am fiddling with the settings.
I’ve enabled “prefer Porsche Charging Service” (which is my preference), but I notice there’s also a new function to search and add another operator.
If I add one here - for example Tesla because often the price is cheaper than PCS operators - does this get higher priority that the PCS ones or equal priority?
Im hoping to achieve PCS chargers being priority and Tesla as a second choice
E500
Herts
Taycan GTS ST, all sorts of others
Not sure (helpful I know) but I had the same thought as you, so disabled the PCS setting and manually added ionity and Tesla like you’ve done… I imagine it’ll still need a little manual route tweaking anyway.
chun
Taycan Turbo 2020, Cayman GT4
Assuming it works like the app already worked.
Equal priority and then it chooses based on aviability and which one is closest. If they are in similar proximity, it will choose whichever will result in shorter charging time.
Dabz
Dabz
J1.1 4S
Perfect, thanks
Flying ace
SF CA
GTS ST, 997.1 GT3, 991.1 GT3
Whoa, this is a big feature update. Sounds like this was a dealership update of the PCM? Was the car there for a warranty fix or service? Can you paste what the work order sheets says for the PCM update?
chun
It’s part of the pcm update 3892; that was released for the navigation issues in Europe.
Sadly, you need to prove that you have navigation crashes to get the update - issues which never existed in USA, so not sure if they will agree to update your car. But you can try - it’s service campaign wtg1 I think
Flying ace
SF CA
Darn, I checked under Charger planner menu, I definitely don't have this on my j1.1
