- David
- Jan 28, 2019
- Santa Cruz
I think this has merit - it will certainly rule out any 12V drain issue associated with remote access - but it's not clear that is the only thing causing these problems - I think it won't hurt, but since it's a random software fault this by no means assures you won't encounter this problem - really there is nothing you can do to prevent this from occuring - like _ANY_ vehicle if your 12V starter power system is offline for any reason - you'll need to "boost" the vehicle to wake it back up…as long as we have 12V batteries involved to start a car - we will have this potential problem - there is NO way around it given current industry standard designs for EV or non-EV vehicle…I wonder if putting the car into privacy mode could prevent these issues at all. I'm about to leave my car sit for 8 days and I'd rather not have to deal with anything like this.
also there are actual problems sometime with 12V batteries simply being "bad" and no longer working as a battery - solution there is to replace the actual failed 12V battery - but it will present as a 12V battery drain problem…
there is no way to avoid this problem - pure and simple - and at the moment there is no indication that Taycan has a systemic problem in this space, and statistically it appears Taycan is no worse in this space than any existing ICE or non-ICE vehicle in terms of actual reliability.
expectations that this can never happen to you is unreasonable for any vehicle - Taycan included.
