Part 3: The Quest for the Perfect Tune
I was just going to ask about this 1300amps as well.
I've confirmed it's all software related
How did you confirm it is software only? It could require changing out battery pyro fuse for example - similar to how Tesla sold the Ludicrous upgrade for P85D, where battery had to come out, new fuse had to be installed, then software limits were changed. Just changing the software on a P85D would probably blow the non-resettable pyro fuse on your first 100% SoC launch.
Mr.Smith
PaulS
Southern California
The spokesperson for Taycan told me.
It could be what is being done through the ASG upgrade
69Mach390
Florida
24 Taycan 4S
I am not sure that one is timed right. I mean it shows valid on the dragy but we've never had any other 4s hit 10 seconds.
BTW keep in mind if you are driving 30-45 in the city then consider stock quartermile to be over 12 seconds as you can't use launch control.
Just wanted to follow up on this. Took my 2024 4S tuned to the drag strip tonight. 21” RS spyder wheels.
10.99 @ 128 mph. 96% charge and 80 degrees out. Very happy. Raced and Ioniq 5N. He did 11.1 at 121 mph.
Porsche Taycan Part 3: The Quest for the Perfect Tune IMG_5052
prj
prj
Estonia
www.mapev.net
Taycan CT 4 - 2026
https://newsroom.porsche.com/en/202...gt-manthey-kit-record-nordschleife-42424.html
“For the first time, the Manthey Kit also includes adjustments to the powertrain: optimisations to the high-voltage battery, control unit and pulse inverters increase the maximum discharge current while driving from 1,100 to 1,300 amps.”
Wondering if they gimped the power of the Turbo GT from the factory so they can sell their kit with “full power”.
Note "while driving"...
They just upped the power in attack mode and base power. The LC power remains the same 860kW afaik.
69Mach390
Florida
24 Taycan 4S
10's is very nice for a J1.1 4S.
For sure. Looks like my numbers are almost identical to a J1.1 turbo, but the trap speed means neither the turbo nor turbo S would want to race without launch control.
I ran 2 more runs, both 11.0. Highest trap speed was 129.
gnr3312
Austin
2024 Taycan 4S
What is a trap speed?
StamStam
Stamatios
Athens
Amazing numbers for 4s!! Tuned turbo can do 10.5? Anyone with some real numbers?
69Mach390
Florida
24 Taycan 4S
The speed at the end of the 1/4 mile. Usually it lines directly up with how much horsepower a car makes and is an indicator of how fast it will be in a rolling race.
For example- the Ioniq 5N I raced was only 2/10th slower but going 8 mph slower by the 1/4 mile.
He launched harder and beat me to 60, but above 100 mph I was significantly faster.
His trap speed and mine were both 101 mph at the 1/8th mile mark. But by the 1/4 mile I was doing 128-129 vs him at 120.
AutoX
LA
Taycan RWD, Model Y, MachE
crazy how fast the Ioniq 5N is.
SoccerMan94043
San Jose
2025 Taycan GTS
What tires?
