PB+ capacity
tim a
Tim
D207346t
taycan 4s
What OBD2 works best for a 4s. I did by one but it was wireless and didn’t give me any readings.
Tango22
Scotland UK
2024 Taycan GTS ST, 2019 McLaren 570S
What's the procedure for carrying out a rebalance?
tim a
Tim
D207346t
taycan 4s
Take the battery % below 2% leave for 6.5 hours. Charge to above 95% leave for another 6.5 hours and check again. I did mine over last 2 days. When at 1% I left overnight and the battery had gone upto 5%. This is normal. All my modules rebalanced to within 0.017 before rebalancing it was 0.072.
SergeyIndy
Sergey
Indianapolis
Tango22
Scotland UK
Thanks, did you notice an increase in range afterwards?
Also, which app are people using with their OBD2's? I have a decent OBD2 reader which I used for my G81 M3, but I used BimmerCode with it and I'd doubt that will work on my Taycan!
SoccerMan94043
San Jose
2025 Taycan GTS
Is that something we should just be doing regularly (without an ODB2 check) for general battery health? Once a year kind of thing?
SergeyIndy
Sergey
Indianapolis
Is that something we should just be doing regularly (without and ODBC check) for general battery health? Once a year kind of thing?
The point of the rebalance is the following I do it every 5k miles:
1) Process allows the bad cells to come forward so you can claim warranty if one comes up bad
2) Process chemically rinses the batteries and gets them to the best healthy state
3) SoH increase is temporary, at least based on my rebalancing results.
SoccerMan94043
San Jose
2025 Taycan GTS
Since I have a J1.2 the actual warranty checking won't work, as I understand it, because the ODB2 interface doesn't work. Points 2 and 3 seems like something we all should be doing.
FWIW, I tried something similar with my Tesla in the past and it didn't do anything :p
SergeyIndy
Sergey
Indianapolis
I am hoping someone will figure out how to get OBD data reading from J1.2. I do agree that points 2) and 3) are of benefit to all Taycan owners and it is following official Porche TSB.
Chris82
Chris
Rothes
Do you need an OBD reader to see if you have bad cells then? Or is it on the PCM?
tim a
Tim
D207346t
taycan 4s
CT14 garage has made a free program that is in the forum. You just need a cable and computer. Do a search for SOH and it will give you all information. This will tell you if your modules need to be rebalanced. It also gives you information on how to do this as well.
Chris82
Chris
Rothes
So search SOH on the forum and the thread should come up? Sorry I’m new to all this.
tim a
Tim
D207346t
taycan 4s
Likewise. It’s all abit daunting but I’m managing to work my way around things. This forum is excellent b
tim a
Tim
D207346t
taycan 4s
I did a search for SOH battery program and it came up.
Chris82
Chris
Rothes
Ye I found it. Some very interesting reading and when I’m home from work in a few weeks I will be trying out for sure. And the other options look interesting as well for updates to the pcm and stuff.
