PCM has gone crazy!
glon
Gareth
London, UK
I’ve had my Taycan for a week and it was fine, but yesterday the app started telling me the car was unlocked and the windows were open when it wasn’t/they weren’t, it also started saying the car was in privacy mode when it wasn’t.
Today I got back into the car and the PCM just wouldn’t t load (I have plenty of battery - about 65%), it just keeps showing the Porsche logo but nothing else. I tried the two fingers in the too right hand corner and reset it but it made no difference. Then, halfway through a long journey it suddenly came back to life, but wouldn’t allow me to use my own profile (it shows my name but it’s greyed out and will only let me use it as a guest). This evenin the app is claiming it’s in privacy mode again.
Anyone had a similar experience? / any ideas to fix it?
thanks!
glon
Gareth
London, UK
Sounds a bit random. I’ll see how it is tomorrow.
not sure if this sounds likely, but this all started after charging with a 3-pin plug for the first time this weekend. Anyone heard of things going strange with the PCM after this sort of charge, or is that just a coincidence?
Gru
Taycan Sport Turismo - 20"
i have a similar issue for a couple of days: app says car is in privacy mode, although it is not.
everything else is fine (so far…)
glon
Gareth
London, UK
Thanks, did it just clear or do you still have the issue?
Gru
still have it. I've read somewhere on the forum that deinstalling the app (1st disconnect) and reinstalling it will solve the issue. it didn't.
look at car stuck in private mode after update (I don't know how to add a link ?)
daveb3473
Dave
Bath, UK
Taycan 4 CT
Mine did that when new also. Now always put keys in front cup holder and not had an issue since…
Midlifecrisis
Worcestershire
Mine has been in privacy mode a couple of times in last month (it hasn’t although the app says it has). A bit annoying as it limits functionality but each time was sorted when I turned the car back on
Nic Suffolk
Nic
Suffolk
Taycan GTS MY’23
This is probably the wrong place to write it, but my PCM screen on my new GTS has hung and just says Porsche and despite me doing that special two finger reset I can’t get it to work so it’s gonna have to go into the dealers despite being only three days old. are there any special solutions that might fix this?
REIL
Rick
West US
Taycan 4S+ / MY20
One more thing to try that worked for someone else recently and has been discussed frequently on the forum is to lock your car with your key fob. Walk away for 30 minutes. Seems to reset everything.
Link from last weeks thread.
https://www.taycanforum.com/forum/threads/home-screen-died.16216/post-249606
Best of luck Nic.
Nic Suffolk
Nic
Suffolk
Taycan GTS MY’23
Thanks for your reply Rick and I will try this. However, this happened on the way to Gatwick Airport where I had to park and run so not the best experience of a three day old Taycan (although it does drive sublimely!)
