Porsche Electric Sound
Andy
Taycan Turbo S
And there’s no option to compare a GTS sadly
Porcupine
South east UK
2023 Taycan CT 4S
I've got a 4S and my business partner has a GTS. As far as I can tell they both make the same sound. A Turbo S might be different but I don't think the GTS has a unique signature sound.
You don't say where in the UK you're based but if you're anywhere near Gatwick you're welcome to come and hear both for yourself.
RGBArgee
Rick
Somerset and Brittany
Taycan 4SCrossT.992 Turbo S.Audi S3 8Y, MG Midget
Can I latch on to this post and ask if there is anyway the Porsche sound can be programmed to come on automatically at speeds below say 30mph… cheers
Perry
Daniel
Sweden
No, but it does of course have AVAS that turns on when driving below (I think) 30 km/h. It’s obviously not the same thing, though, as it is a safety feature above all else. Otherwise, probably the closest thing you have is binding one of the shortcut buttons to sport sound toggling.
RGBArgee
Rick
My steering wheel shortcut is for noise.
Andy
Taycan Turbo S
That’s very kind thank you but sadly I’m way up in the NW.
I may nudge my OPC for a test drive of a GTS.
I do wonder whether the Taycan GTS uses the same concept as my last 992 GTS, namely using less sound deadening in strategic places to increase cabin sound; certainly felt that way when I last test drove a GTS.
BullitX
Basil
BMW 530e G30 LCI
Is the Sport Sound louder on the outside than the pedestrian safety sound??
I’m sure you know the answer ?
Well, in uses energy, so takes away available power, but it might create some aero tunnel with the sound vibrations (like ships which add bubbles to the water, causing it to "slip" passed the boat with less resistance). ;)
A.Mayor
Netherlands
Audi, Porsche
Quite right! The tech works by generating an acoustic pressure wave, which creates a frictionless micro-tunnel by modulating the sound frequency and amplitude. This “magical” acoustic tunnel pushes against and heats the air, reducing drag. So essentially, Taycans with Sport Sound are serenading the air into stepping aside, zooming ahead with less resistance and, dare I say, more style! ??
