*SOLVED* - locking your doors WIHTOUT keyfob - using your hand...
Jrkennedy37
Dallas TX
Each of our four doors have different sensitivities, with the drivers door being the least reliable. Anyone else noticed the same?
I’d say we’re at 25% odds the Taycan locks from the driver door the first time vs 98% on our Panamera which takes much less purpose/effort.
chylld
Jonathan
Sydney, Australia
CT4S
Fortunately, I don't have that problem. Because I have a Cross Turismo, I have to lock with the key - to avoid a false alarm. Lucky me!!!
You can deactivate the interior sensor by also double-pressing the door handle notch... assuming you can get both touches to register.
feye
Shenzhen, Munich
Porsche Taycan 4S+ 2020
Will try, thanks.
Mostly I use the close & lock button on the trunk, otherwise the fob. No biggie...
John89
Midwest
I do NOT understand why this is difficult for anyone.
Put your finger on the dent in the door handle.
Hold it there until it chirps.
Done. Works 100% of the time.
Absolutely doesn't work on mine 100% of the time. It intermittently works. Annoying.
4thPcar
Del Mar CA
Sorry @DerekS, that doesn't work for everyone. It works for me about 25% of the time. I've given up, I just use the key fob to lock. Be thankful you have the magic touch!
kreshi
hansi
Taycan 4s
If you have your phone or a RFID blocking wallet in the same pocket as your key, it often will negatively impact the signal. When I have my key in a separate pocket, works 99% with tap and hold for 1 sec.
BigBob
This is only if you have the 'comfort access' option i assume? Or can you lock it like this without it?
According to the internets and this forum - seems like everyone is having issues with something these Taycans are SUPPOSED to do easily - lock the doors after you get out without the keyfob...
Story (from Porsche) goes - if you get out of your car - and touch the handle (with the keyfob on your personage) the doors are supposed to lock.
and - if you're lucky - it happens 1/4 of the time. I've read posts about : "hold it in your left pocket and use your right hand to touch the door handle..." or "DO the Karate Kid Crane Stance and then use your middle finger to.."
ANyway - i accidentally stumbled on something that works on my car - on all 4 doors, 100% of the time, AND on two cars at the dealer that i got to mess around with
it's NOT my job to say why this works - but i have my guesses. Just try it and let everyone know?
do what you've done before - just use the backside of your hand - specifically the back side of your fingers. I know it's dumb. Maybe my big manly calloused hands aren't as conductive on the normal side you touch things with. Again, no idea - but it works
i do my finger like this: (see image)
and use the back of my finger - the second section. And then hit the little indention on any of the doors and it locks like it's supposed to when you do a normal human touch to that area
Yes, it's silly and int he grand scheme of things - no big deal. But yet, for some reason it is. I NEVER would have thought of posting this - except i've literally seen over a dozen people complain about how they can't get it all the time.
PS - if it doesn't work for you - you're probably a descendant of bastardized alien race who comingled and bred with humans. And it'll never work for you
Here's a vid of it
Nice!
Not had the issue but note that you need to have Comfort Access as an option (not standard in many countries) for this to work in the first place.
I obviously have the 'magic hands' .... live long and prosper
Porsche Taycan *SOLVED* - locking your doors WIHTOUT keyfob - using your hand... 1645525645172
Dee
Dee
A lot
Here's a vid of it
Why does that look silly?
I do that all the time with the back of my four fingers.
Just like I open the frunk.
I slide along the door handle from front to back, works every time, even in rain.
No problem.
Pozuelo
Roberto
Madrid, Spain
Another possible factor no one here has taken into account is the use of hand creams. I have fingerprint access to my home and I noticed that the ones that had trouble often to open the doors used hand cream. So my recommendation is to not apply any to the finger you are going to use to lock/unlock your car. :) Probably acts as an insulator…
Sparky
Joe
Norfolk, VA, USA
2022 CT 4
Just to add to the mix ... when I use the drivers door with my finger, the car will lock and then immediately unlock. Now I use the back door and no problem.
atebit
Bob
PA
For a moment I thought there was going to be a link at the end of the first post where I could learn to do this One Simple Thing to lock my Taycan.
Genau
Reston, Virginia
Perhaps it is PPF on the door handles that prevents the normal finger press from working reliably, or the type of PPF. I have PPF and experience this issue, along with the frunk “swipe to open” not working easily.
DLP
Ice Grey Turbo
Exactly!!
Just rest your finger on the groove ...... works every time
bluegrassvroom
bluegrassvroom
Neil
Kentucky, USA
2021 taycan 4s
follow-up question... I'm one of those people who the touch with fingertip/hold to lock DOES NOT work 100% of the time (except with the New, Improved, back-of-finger method)
but my car does NOT always unlock when i walk up to it 100% of the time
how about everyone else -
if your car does NOT lock like you think it should by hand/finger - does it UNLOCK perfectly when you walk up to it? Every time?
Same question for those who NEVER have a problem finger locking - does it UNLOCK perfectly when you walk up to it? Every time?
