magnitude
- Heinz
- Apr 13, 2023
- North California
- 2021 Taycan Turbo
- #1
Being in the Bay Area with a garaged car, the heater is not really something I had to use yet. If anything, I've had to cool using the A/C, or merely resort to seat heating.
But the other day, at the end of the commute, I thought I'd try it out, with all the heater failures you hear about. The air that came out was not very hot at all. Then again, I was at the end of my commute, so did not give it much time. By the time I was home, I felt that the air was a little bit warmer.
Now I have no idea what to expect, this being my first EV. I know it's not like in a car with an external combustion engine, where a warmed up engine will give you heat instantly. Presumably the heater needs some time to come up to temperature? How long?
And would a heater failure really only affect heating, or cooling as well? I heard it's rather a heat pump? "Unfortunately", I don't need much A/C in the Bay Area either, so if that doesn't fully work I'm not sure I'd notice as well...
