- Jul 30, 2021
- WA, USA
- 2023 Taycan TCT, 2024 Q8 eTron P+
“Parallel rules” are not part of Ohm’s Law, hence they are listed in a separate column in the table above. There are plenty of rules used to analyze circuits, impedance (vs. just resistance), or even a rule that states that all currents into a node must add up to zero. It doesn't make them part of Ohm's law, which is "V=IR". How you obtain V or I or R is not part of Ohm's law.The Tech spoke on how the batteries were wired. Thats his understanding.
As far as as OHMs law -
Ohm's Law (V=IR) applies to both series and parallel circuits. In series circuits, the total resistance is the sum of individual resistances, and the current is the same through each component. In parallel circuits, each component experiences the same voltage, and the total resistance is less than the smallest individual resistance.
So to the comment about how the battery is wired does apply via this law.
- So don't believe every reply you see on the internet.
