- Jul 30, 2021
- WA, USA
- 2023 Taycan TCT, 2024 Q8 eTron P+
The UI/UX is incomplete, and that in turn makes it difficult and confusing to use.The source of the discussion and frustration is missing features. Not complex UI. The fix appears simple and within the framework of the current UI by adding two settings.??
Imagine you you got keyboard with no "R" key (by design, it didn't just fall out). You can still use it, but now the user experience is much more convoluted and hard to use. For example if want to type "hour", just type in "houe", then right click and choose "hour" for spell check correction. You can also copy-paste "r" from elsewhere in the document or from the web, or use word completion in some cases. If reviewing usability of such a keyboard, would you call it complex to use, or "not hard to use, just missing a feature"?
Porsche compounded the problem with the UI by allowing timers to charge to less than profile, which has an ambiguous meaning at best. It might have been done on purpose as a bandaid to the lacking TOU settings, but it created a very confusing user experience instead (much like typing on an R-less keyboard ).
