TPMS + PARK ASSIST + TEMP READER no functioning (HELP!)
billas23t
Billy
Athens
Porsche Taycan 2023
Hi everyone,
Today I woke up , started the car and got all these notifications that the TPMS (tyre pressure) , my temperature reader outside and park assist is not working for some reason.
What can I do to fix the issue.
p.s. when parking , I slightly touched the front end to my parking wall, barely touched the number plate, Voula that have caused it?)
pleas help!
thank you in advance
trycan
Difficult to guess at what caused those error notifications to appear.
I will say that the parking sensors in the bumper are extremely sensitive and there is no way to assess what you describe as "barely touched". If you came into contact with a solid brick or cement wall (even no visible damage), it's possible the sensors are out of calibration and need to be looked at by a dealer.
kurand
nowhere
None
pop the centre section of the sensor cover (the one that has the ray dome) off the bumper and check that all the sensors and wires are still connected and mounted correctly. if all looks good, then you’ll need to read the error codes with an ODB reader to find out what’s gone wrong.
or just take it to your dealer for a fix.
tophamn
Neil
Bristol UK
Taycan ST GTS
Experience tells me several random electrical errors all at once suggest the 12V battery is low or failing.
