CAN SMALL ANIMALS ACCESS TAYCAN WIRING?
RAH99
Roland
Southern California
2023 Taycan GTS
Hi All, it looks like a rabbit got into our garage and got into one of our cars and chewed the wires causing 'malfunctions' in the car. Unfortunately, my Taycan is in the same garage and I am wondering if a rabbit can somehow get into the wiring of the Taycan and cause big problems as well????
Last we saw, it crawled under the Taycan and then disappeared around the back wheels. Couldn't find it or hear it. Tried to use the hose in the wheel wells and visible suspension, but nothing moved. Now have some lettuce as bait to make sure it's still in the garage while waiting for a Rabbit trap.
I know it sounds a little humorous, but it ain't :)
Just want to know if I should be concerned with a rabbit within the underbelly of the Taycan? Or park it outside hoping it eventually comes out and runs away, although not being able to witness it.
Can't wait to hear the answers :)
SergeyIndy
Sergey
Indianapolis
FlyingPoint
Cobblestone
I have come to learn that in the animal kingdom, anything is possible.
Rabbits are pretty finicky, but since their teeth continuously grow they tend to gnaw on anything. Soy based insulation would be a welcome treat.
JimBob
Toronto Canada
I had a red squirrel get into my Taycan in the garage and chew through the wiring for one of the front headlights. And left a stash of nuts behind. I now always keep the garage doors closed and and bird food in a sealed plastic box.
roger-on-taycan
Roger
Santa Cruz, CA USA
2025 CT4, 2019 Audi e-tron, 2001 SLK 320
I remember when our 2019 e-tron was about 5 months old I opened up the trunk one morning for some random reason and found this, photo attached. Looks like a bunch of scavenged insulation material makes a pretty good nest...
After cleaning that up (and ejecting the critters) I put a packet of Fresh Cab rodent repellant in there, and haven't had problems since. I did the same when I got my Taycan.
Porsche Taycan CAN SMALL ANIMALS ACCESS TAYCAN WIRING? B84BE63C-C3FF-4DDD-B505-7597EFA0C43B_1_105_c
Jeremy
St. Louis, MO
2022 Macan S; 2021 Taycan 4S
Is the rabbit ASE Certified? If so, probably okay. If not, I would ask it to stop whatever it’s working on. You’ll just have to get the work redone.
Or it’ll invite its friends over. ?????
RAH99
Roland
Southern California
2023 Taycan GTS
roger-on-taycan, good call on the Fresh Cab that I just ordered. Where did you put the pouches in your car?
Tucson_Jim
Jim
Tucson, AZ
2021 Taycan turbo
We live on the edge of the desert and pack rats have a dietary attraction to the plastic sheathing around Porsche electrical wiring. We’ve had two Cayennes that provided $3,000+ meals. Our local dealer said it was due to the sheathing having a soy component. Now all cars are garaged.
roger-on-taycan
Roger
Santa Cruz, CA USA
On the Taycan, under the hood, underneath the snap-in plastic cover that provides access to the 12V battery terminals. Off-center on the driver's side, pretty close to the windshield, there's an approximately 8" square area that seems pretty safe and self-contained. Last time I checked it was still there.
d00d
4MB, HYA
yes
Found a half eaten chestnut in that location.
When I park outside, under the Taycan at each wheel I put a Kaloo pizza peel with three Tomcat traps and Provoke bait.
Haven't caught any field mice there yet, they seem to be more attracted to the ICE cars for some reason.
Porsche Taycan CAN SMALL ANIMALS ACCESS TAYCAN WIRING? IMG_2890
Fish Fingers
Sold
Not sure where I saw it (maybe here?) but there was some kind of mesh to park each wheel on, that animals don't like walking on.
Not really something we have much of an issue with in the UK afaik.
kort
'23 Lucid Air GT
the taycan is a car, just like any other car, the only difference is it's means of propulsion, that said, like any other car it is vulnerable to attacks from critters that can cause severe damage to it's wiring and other systems.
RAH99
Roland
Southern California
2023 Taycan GTS
Hey Everybody,
UPDATE
Finally got the little critter out from under the rear of my Taycan by enticing it with lettuce in a trap. It took 2 tries but it finally walked in and the trap closed on it. Drove it down the street into the hills hoping it doesn't have Waze to find its way back to my house :)
Put some mint bags in the trunk and frunk, hoping to avoid this happening again!
Thank you all for your comments and inputs. Good Forum here!!!
Porsche Taycan CAN SMALL ANIMALS ACCESS TAYCAN WIRING? rabbit
