- Peter
- Nov 3, 2019
- France
- Taycan T, Aston Martin DB9, Porsche 996 C4 Cab, i4
I do not think this is correct. You probably have never had the connectivity problems.You should be fine - the default go to control point is within the PCM and forget the apps. Remote access via the app is not an essential requirement - inconvenient at times may be but that's it. Remote control of climate and start and end control of an AC charging session is not essential either - simply have your profiles (3 locational + 1 general non-location specifc) and timers (you can have 4 of each) set for charging overnight when remote and signal issues prevail - it will be a doddle.
You are correct in that the services like Clima control as well as the adjustments to charging will not be available and that is not the main problem. The app communication is flaky at its best.
But worse is when the system does not reconnect to the Cellular network, the following will not be operational.
- There will not be any download of your seat positions or mirror settings.
- No download of radio stations, destination favourites and no search for charging stations!
- No internet radio stations or Apple Music, news, weather etc. All greyed out.
- Worst of all no traffic information, see @tigerbalm trip report to Norway on return.
- you might observe this when there no longer are satellite images displayd in the navigation.
- The green light for emergency calls can still be active and can be explained by the Audi diagram above.
- And no information about trips etc sent to the Porsche servers.
