Deeply disappointed with 4S -- 12V battery issue and "Electrical System Error"
NC_Taycan
Lewis
Wake Forest, NC
I’ve had 2 battery issues with my Taycan 4S
1) both key fob batteries completely dead within 3 months of ownership with very light usage. Apparently, the car kept communicating with the fob and the red light on my key kept blinking thus draining the batteries.
2) the 12v issue everyone else is talking about here. Car completely dead while it was plugged in! The point of having an EV is so it’s plugged in and ready to go. I shut down using the start button and locked the car. I noticed that the car automatically unlocked and then eventually drained the battery while it sat for about 4 weeks unused. I was using the app and had a charge timer and climate timer set.
Very frustrated that there are electric issues like this for so long and yet Porsche still hasn’t figured it out. Not ok to say wait for a software update and in the meantime stop plugging it in and stop using the timer and apps!
These might be related. Some have resorted to shielded bags for key fobs if the keys aren't kept far enough away from the car. Disappointing none the less.
kort
'23 Lucid Air GT
pro tip, do not store the keys within close proximity to the car because of this issue
Nipri
Rajesh
Ice Grey Taycan
Just about to order Taycan in the UK for May 2021 delivery & am hoping that all the issues mentioned in this posts have been sorted.
Beginning to wonder if should continue or not with the order!
dgompper
Iowa
2021 Taycan 4s
I keep both keys in a faraday pouch while at home, and I also log out of the Connect app in my iPhone each evening. I believe that by disconnecting both from communicating with the car might help to minimize a possible 12v battery drain. I hope.
Nipri
Rajesh
Ice Grey Taycan
Thank you so much for the tip. Will do once the car arrives. Have told the dealer of the issues that some members are having & has assured me that all will be ironed out by the time get my car.
Fayaz
Fayaz
Canada
Yes the keys are within 10 ft and one wall of the car. I noticed when I had the app and the car plugged in with the key close by that the car would unlock and the key continued to flash until drained. Currently I deleted the app and have the car unplugged which seems to have resolved the key drain and unlock issue. But we shouldn’t have to resort to this or to keep the key protected and far.
NC_Taycan
Lewis
Wake Forest, NC
Logging out of the connect app is not necessary. The car will still periodically check in with Porsche via a second low-power telematics connection (in the OTA control module). Your app simply gets the updates from that same Porsche server. Now if you go into the app and change something in the car, that's a different story...
kort
'23 Lucid Air GT
"But we shouldn’t have to resort to this or to keep the key protected and far."
if you want to enjoy the technology you need to accept it's limitations. how hard is it to place the key out of range of the car? SMH
chrisk
I don't thing the problem is to keep the key far from the car. The problem is that Porsche did ask the Taycan owners to do so, so some owners had to find their cars dead. Even now, Porsche has not officially communicated this advice to the owners, we just heard about from forum members who found out after a dealership visit. In my opinion, this lack of transparency and communication is the issue.
kort
'23 Lucid Air GT
the same thing happens with the tesla key fob and I suspect it is the same for cars with similar systems. these remote key fobs have been around awhile
mc9er
Wisconsin
2021 Porsche Taycan 4S, 2021 Audi Q7
How far away are we talking? Is there a way to “test” if too close? Have a drawer we keep keys in ~15 feet from the cars (through a door/hallway)
Fayaz
Fayaz
Canada
Just to note none of my other cars ever had this issue. But with the Taycan however I did test it. The key flashes continuously when just passed 1 wall and 8 to 10ft and unlocks the car and unfolds mirrors. When I moved it about 25 ft and 2 walls away it was fine. Both instances with the car plugged in and app installed but not active. With the car unplugged and app deleted the issue seems to have vanished even within close range.
NC_Taycan
Lewis
Wake Forest, NC
There is a key difference here - the Taycan writes to the key and the key has visual indication of this. If you see the red ring around the Porsche crest light up at any point, the key is in range of the car. So, if you see a red flash from wherever you wish to store your keys, you need to move them or shield them.
Side note, I don't know why it is designed to write the last user ID to the key many times over after shutting off the car - once would be sufficient. Maybe it does so to ensure the write succeeds...
Dan3141
Dejan
SF Bay Area
2020Taycan 4S
So far Porsche has not come back to me. Car has been at the dealer more then 2 weeks.
1800 Porsche calls have not resulted in anything. Will likely turn over to legal tomorrow afternoon.
Dan3141
Dejan
SF Bay Area
2020Taycan 4S
Ok so real time update.
An incredibly polite guy from Porsche called me, got the dealer on the call (seems like they had issues getting service advisor from dealer on the phone). Dealer repeated the "battery wont be here at least until end of March" so now they will escalate further up the chain at Porsche.
Today is the first time I feel that Porsche did what they were supposed to do.
D
