Goodyear Eagle F1 Asymmetric 6
ChronoMax
Mamba Taycan CT
Time to replace tires 20" CT4.
Everyone seems to like the Asymmetric 5, but what about the 6? Haven't found much feedback on them. How new are they? N rated?
Maybe the 5 is still the one to get?
refazi
Refael
San Francisco, CA
you could fit them but they are not NF rated, only 5 is NF0 and NF1 rated but on the 21" sized for the sedan.
newbeach
Stockholm, Sweden
4S CT
I just went from my 20 inch winters to the goodyear 5s 21s and my god are they loud! Trying michelins next round I think
ChronoMax
ChronoMax
Mamba Taycan CT
Ok sounds like maybe not the best choice then. :(
What is the consensus today for a daily driver / commuter 20" all season all around tire for the CT4?
Jonathan S.
Jonathan
Amherst MA & Twin Mtn NH
tinyurl.com
Michelin CrossClimate2 if you want it to do double duty as a winter tire.
Otherwise, Continental DWS 06 Plus.
ChronoMax
ChronoMax
Mamba Taycan CT
Thank you Jonathan S. for the suggestion!
I dont think we need the severe snow service rating.
The Conti DWS 06 Plus looks perfect, however not available in 285/40-20 unfortunately it seems
Maybe our best bet for 20" is just to go with the old tried and true PS4's? Happy with them in the wet with the 997. Will do some more research but happy to hear other opinions and feedback
Porsche Taycan Goodyear Eagle F1 Asymmetric 6 NoFit
Jonathan S.
Jonathan
tinyurl.com
Ah, now I remember -- available in the Taycan staggered 21" but not 20".
(Some of these staggered setups seem like a conspiracy to induce madness via tire model available! Our i4 is the same way...)
Vercingetorix
The O. C.
https://www.tirerack.com/tires/tire...0EF1ASXL&vehicleSearch=false&fromCompare1=yes
Tango22
Scotland UK
2024 Taycan GTS ST, 2019 McLaren 570S
2024 J1.1 GTS Sport Turismo on 21" Spyder RS wheels here. Went from Pirelli PZero's to NF1 Goodyear Eagle F1 Asymmetric 5's recently.
They don't seem any louder than the PZero's, dry grip seems about the same, as does comfort. Wet grip and performance in cold conditions (I'm in Scotland, UK) over the PZero's is noticeably better. Very little in the way of the Ackerman effect in cold temperatures, compared to the PZero's which made an awful noise and skipped badly when turning at slow speeds, pulling out of junctions.
Will see how they do wear rate wise, PZero's had about 2.5 to 3mm left at 16k miles. Anything approaching that on the ASY5's would be good.
Unfortunately on the J1.1 on 21"'s the choice is essentially PZero's or ASY5's. Which is disappointing as I had PS4S's and CSC7's on my previous cars (G81 M3 and M340i Touring) and they were fantastic.
SoccerMan94043
San Jose
2025 Taycan GTS
You can get PZero Rs, yes?
Tango22
Scotland UK
Yeah, but for a 'daily' vehicle they are a bit overkill.
I only just get away with using standard PZero's and ASY5's all year round!!!
To be fair, I'm retired so I don't have a commute and if I look outside and it's icy or snowing, I just chill and sit back down again :giggle:
tophamn
Neil
Bristol UK
Taycan ST GTS
Interesting note: my old Asymmetric 3s were really bad with 'Ackerman' noise/skipping - then I replaced them with exactly the same tyres: nothing! - no noise or skipping on full lock. The old fronts looked fine except when removed the inside shoulders were down to the cords 😲.
Conclusion: I suspect the 'Ackerman' problems are more related to worn tyres than which tyre, though admittedly some will be better/worst than others.
Murph7355
Andy
Hankook ion Evo work really well on a Taycan.
Not N rated in J1.1 21" Spyder sizes but don't let that put you off.
And not the all season version.
Quiet, grip well, wear well. Possibly a slight improvement in range (but not empirically tested).
Have also used them in low temps and they were fine (not used in snow and ice).
