Boss Hogg
- Jun 12, 2021
- UK
- J2 ST Turbo, 981 GT4
This looks normal to me. I used to do the exactly same pre-heat setup as you via timers and the battery is 100% is preheated to 13 degrees C every time using 2-5% of the battery (PB+) in winter when not connected to an EVSE. I stopped using the timers for this reason and just use the phone app for a 10min cabin heat but it will keep preheating as you drive however you have a short commute.
I have a CT 4S the same as you, the battery pre-heat may be specific to the CT as others don't seem to see the same behaviour. It would be good if you could choose what to preheat as it appears the feature is designed primarily for use when connected to a an EVSE.
