Power cord replacement - 7pp.971.678.ed
kewina12
Kevin
Los Angeles
Like some others, my PMCC overheats and this video shows the end result! I need to replace this power cord: Part # 7pp.971.678.ed
Does anyone know if this is the equivalent part (for NEMA 14-50)?
https://www.suncoastparts.com/product/skuhybg2nema1450.html
Thanks in advance
TaycanCook
NYC
MG 4S CT
kewina12
Kevin
Los Angeles
nev
for what porsche charges for the Powersupply cables you can almost purchase an entirely separate, more reliable, same speed, fully compatible, and non-overheating NEMA 14-50 EVSE…
but the suncoast part _IS_ the NEMA 14-50 power supply cable for the PMC+/PMCC…
what NEMA socket are you plugged into?
https://www.taycanforum.com/forum/t...uide-to-the-porsche-evse-pmc-pmcc-pwcc.13886/
@daveo4EV - I have a NEMA 14-50 and had 2 Teslas in the past using the same outlet and never had a problem overheating.
I’ve read through all of your posts and seems unless I want to buy a new EVSE, the easiest resolution is if I have a 50A / 14-50 set-up at home, instead of charging at 40A, should I just charge at 20A and not leave it plugged in for longer than necessary? Thoughts? Also, dumb question, but if I just have a PMC+, where/how do I adjust down to 20A?
Appreciate all you do on this forum.
IanG
Los Altos Hills, California, USA
2022 Taycan GTS
@kewina12 - you can use the settings of the PMCC (accessed in the PMCC menu) to charge at less than 40A - I have mine set to 32A and it works perfectly, not too hot (although obviously takes a bit longer to charge than at 40A)
