Brake pad wear
4SShadow
Las Vegas
2025 Taycan 4S
I dropped my Taycan off at the dealership for service, and they sent me the standard wear-and-tear inspection report.
The rear brake pads measured 7 mm, which they marked as green, but the car only has 9,000 miles on it. Front pads measured 9 mm. Curious how other Taycan owners are tracking on rear pad wear. Does 7 mm at 9,000 miles seem normal, or are others seeing less wear at similar mileage?
Porsche Taycan Turbo
My rear pads are 7mm. Front pads are 9mm. Car has done 40k miles. A lot of braking is done through regen
SergeyIndy
Sergey
Indianapolis
Yes, this is normal. Brake pads are only replaced due to age at a 6 year mark and never for wear, so do not get into the dealer trap to replace brake pads.
SoccerMan94043
San Jose
2025 Taycan GTS
I received my CPO in early December 2025 with 500 miles and standard brakes, was delivered to me with 8mm Front and 9mm Rear, according to the CPO report:
Porsche Taycan Brake pad wear 1783442599643-9
In mid May 2026 I had some rattles looked at (at 2800 miles) and their standard inspection report lists 9mm Front and 7mm Back (the front grew 1mm and the back lost 2mm).
It's not clear who was wrong (I didn't ask for a follow up) but the CPO inspection also had the wrong measures on the tires (I had the sales guy take a picture of the tire being measured and cleared that one up).
It's clear they can't be trusted to measure things. Question any measures they give you and ask them to show you.
69Mach390
Florida
24 Taycan 4S
I received my CPO in early December 2025 with 500 miles on it with 8mm Front and 9mm Rear, based on the CPO report:
In mid May 2026 I had some rattles looked at (at 2800 miles) and their standard inspection report lists 9mm Front and 7mm Back.
As long as they’re “fine” does an exact measurement really matter? Would it change anything if they showed you and both were really 8mm?
Unless I end up racing around a track, I don’t expect to need to change the pads in the lifetime I own the car.
SoccerMan94043
San Jose
2025 Taycan GTS
Based on the break pad, rotor and tires measures in the CPO report, at only 500 miles, I assumed it was tracked and almost didn't get the car. The Sales person assured me it wasn't (it's was from a long term customer of his) and follow up measures made me feel a better. As @DerekS found with his brakes, their CPO inspection is suspect at best.
69Mach390
Florida
24 Taycan 4S
Yeah in that situation it definitely would matter. 👍
