Electrical System Fault + 12V?
Bennachie
God's own county..
Taycan 4S Cross Turismo
Why cant you use the cigarette lighter socket - I used it for 6 years with the Macan. Plug in close the door. forget.... Itknows that it has incoming and stays live as opposed to outgoing when it shuts down............................
Richard.
Taycan GTS
Mine went flat in 6 days (3rd recent occurrence). The OPC is adamant that there is nothing wrong and are blaming an over the air update.
nrps1
Nathan
This is my suspicion, mine went flat similar times twice, it's been OK since, but had been fine for a year.... Others were having the same reports all at the same time.
anonymouse
Oxfordshire UK
What OTA update? The car is supposed to notify you if there is one, and there have been no such notifications other than map updates...?
nrps1
Nathan
None since Xmas time?
I use a CTEK 12V lead acid charger on all my little used cars to keep the battery in reasonable shape so I ordered the Lithium ion one to try on my Taycan, at least it will show where its at.
nrps1
Nathan
Only one since forever in my case. No bugs are being fixed OTA. (Latest model may be different.)
Ah well maybe that is the case then. Perhaps I just assumed because my Tesla updated all the time this was similar. Might have known! Tbh every time I've added or removed a feature ota it's totally broken the software resulting in service visits (4 times so far in a year 0% success rate). Bl00dy useless!
nrps1
Nathan
I got a similar one, on testing 12v only needed 20 mins charge time so seems the car has got over the weirdness.
anonymouse
Oxfordshire UK
Not sure whether we have conclusive evidence of that yet - nor consensus on what the root cause is, and therefore whether it will recur. Mine is staying on the ctek for the moment just in case.
Richard.
Taycan GTS
My Taycan has never asked if I want to apply an update. The only time I’ve been aware of one was one occasion when it locked me out of the display, unannounced, for over an hour while it sorted itself out.
