How many charge to 100%
Just curious on how many of you charge to 100% and how many to 85% on the daily?
  • Total voters
    308
kort
'23 Lucid Air GT
Agreed, but I guess my goal (which is hopefully consistent with this thread) is to be as compliant as possible with the manufacturer’s charging guidance. Tesla’s was “always keep it plugged in”. That was easy, pull into the garage & plug it in. If Porsche’s saying to only charge between X - Y %SOC, then I’d like the car to manage that if possible so I can again just plug it in upon returning home & forgetting about it. So it seems like the only way to do that is with the wonky profiles.
the only thing those wonky profiles do for me is control the max level that the car will charge to. it is convoluted, to set it to charge to 80% you set the minimum to 80%. so if it makes you feel better create a profile that charges the car to a max 80% and plug the car in whenever it is parked at home, the car should not charge beyond 80%. I have a second profile that will charge to 100% and use that one as needed.
SCSEV
Scott
NW Ohio
‘21 Taycan 4S, Audi e-tron, Chrysler Town&Country
Exactly what I do. I have 3 or 4 profiles with different max charging levels depending on the goal that day/trip.
atebit
Bob
PA
Well the impression I got from @epirali ’s post was that using a timed profile would let me set both a minimum and a maximum SOC. But I just tried to set up a timed profile in the Connect app & the options were no different than what I can do using the General profile. So ??
epirali
Edmund
USA, East Coast
So what I have is a profile with a percentage that is the minimum. When I plug in it will make sure the car is at that minimum or above. For me that’s 40%.
I set the desired SOC (the maximum) on the timer for the time I need to depart. So its a percentage but its now the desired SOC. I assumed this for you will be higher than the minimum. So it may be 60 to 100%.
Am I missing something?
atebit
Bob
PA
Ah, ok...so maybe “minimum charge level” = “General” profile minimum charge level, and the “timed” profile = “maximum charge” level?
ron_b
Ron
SF Bay Area, USA
I don't think so, this only applies to T because their phantom drain is so high... ;)
Maybe you’re familiar with a different quote: “An unplugged Tesla is a dead Tesla.”
Well I joke.
feye
Shenzhen, Munich
Porsche Taycan 4S+ 2020
Yes!
Profile = Min charge level to be reached right away.
Timer = Max charge level at a certain time.
J0EL
Y1ADB1
2021 Taycan 4S
My car is at the dealer to repair the rear glass issue. Im not sure how many days my car will be there but they've charged my battery from 54% to 100% despite me telling them not to charge it.
They "must" know it is not good to leave it at 100% overnight.
How angry should I be? Im at level 10 right now!
How bad is this for my battery? Its gonna be at least 12 hours fully charged before they open tomorrow
submatrix
2021 Taycan
It's fine. Leaving it at 100% a few times won't have any tangible effect on battery degradation. Just don't make it a regular habit. It's not like if you leave it at 100% for 12 hours your battery suddenly loses capacity.
J0EL
Y1ADB1
2021 Taycan 4S
Thank you for replying.
I turned on the A/C from my Connect app.
Hopefully this does something.
edit: 15 minutes A/C on... lost 3 miles of range but battery stays at 100
atebit
Bob
PA
Hmm, the timer didn’t do what I wanted:
- Leave car plugged in all the time.
- Don’t start charging until SOC <= 25%
- Once charging, stop at 85%
since this is ~ what Porsche suggests (“don’t charge all the time”).
…I can haz?
Torv
Torv
Marin County, California
I confess that last night I charged to 100%, but my car is brand new and I want to gauge real world range at 100%. I will, most assuredly, charge to 85% on a regular basis.
feye
Shenzhen, Munich
I always charge to 100% at home... Degradation is inevitable and mostly comes from overheated DC fast charging. :)
amazing
Matthew
Asheville, NC
2003 M5, 20 Merc Sprinter 4x4, 21 Taycan 4S, 22 Rivian R1T, 24 Ineos Grenadier
I have my minimum charge set to 25% for Home location profile. I'll charge it to whatever I think I need it for if I am going to use it the next day.
epirali
Edmund
USA, East Coast
As others said not a big deal on occasion. But yes a little bit of anger is justified, more because the dealer DID NOT hear you instructions. In this case its no big deal, but its not ok. I get the same when I explicitly ask them NOT to wash the car (then they use terrible methods) and they proudly hand me a ”freshly washed” car back…
