Loadspace Partition Net
JAGMAN
RI, USA
‘22 CT4
I use it too despite not being able to see out the back. Install and removal is easy. I do wish it rolled into the seatback as it does on my cayenne.
SECRET
Taycan GTS ST
You also can use it behind the front seats to separate yourself from folded rear seats or rear passengers - kinda like a taxi.
Are there OEM points between the front driver/passenger & rear seats to secure the top & the bottom of the partition?
Jrkennedy37
Dallas TX
yes, but I believe someone mentioned you have to spec the car with the partition net from the factory to receive those mounting points.
SECRET
Taycan GTS ST
Ah makes sense. My car spec is about to lock in 3 days (FINALLY! Thanks @ssim!!), and I'm currently speccing the partition to at least have the flexibility of using it if I needed it. Does anyone have any drawbacks that they've noticed from speccing it from the factory?
No drawbacks and is the right thing to do.
The net is fiddly to use however and will require some contortions to set up.
I have one and not used it.
Nigel
West Midlands, England,
Audi A4, Porsche Taycan GTS ST, Jeep Cherokee XJ.
Hi there, I have the same net with a GTS ST, I think the fold out sections only come into play when the net is placed just behind the front seats (there are two positions along the roof, one for the boot and one behind the front seats). I just clipped it into the top and then used the clips on the boot hooks tightening everything up. Looks about right and seems to work, picture if needed.
ciaranob
Nope - well not true in US market as my 2022 CT has them but never ordered the net - this also was mentioned in older threads.
