My charging not starting at the programmed time
Singularity
Finland
MY25 Taycan Turbo, MY22 Audi Q7 60 TFSIe
Some of the terms there are definitely confusing but here are my thoughts on what some of them actually mean.
Optimized charging
This has caused some confusion but I'm fairly certain that this mode simply means that the car will not interfere with the charging process other than in regards to the set minimum (which actually is also a target).
The "suitable equipment" line there means that the car leaves timers and other fancy stuff to the responsibility of the charger you're using. The charger outside the car controls how and when the charging happens, not the car. That's what in my opinion "optimized charging" means.
Minimum/target terms in the software & manual
Again due to how things actually seem to work, these are in effect the same thing. It will charge to that level and then stop. With timers it will do it in specified timeframes and with just a minimum profile it'll charge immediately and then stop.
Here are a couple of lines from the "good to know" app in regards to this:
General
"Use the Timer or Profile function to programme a maximum high-voltage battery charge of 85 % for daily use of the vehicle. The high-voltage battery is always charged to the minimum charge level programmed in the Profile function, even if a charge timer is active."
Timers
"The Timer function ensures that the high-voltage battery is charged to a specified charge level at a programmed departure time."
Profiles
"The high-voltage battery is charged automatically to the programmed charge level during the specified charging times when the vehicle is charged using alternating current (AC) and provided that no timer or location-dependent charging profile is active."
"The profile function defines the charging process, which then starts automatically. The high-voltage battery will be charged to the specified charge level within the programmed charging time.
The high-voltage battery may not be fully charged depending on the minimum charge level programmed."
So in summary the manual is in every section talking about charging TO a specified charge level, regardless of using the timer target or profile minimum.
UroDoc
Lone Star State
812 Superfast; AMG GT 53; Taycan 4S; DB11
Thank you all for the help with this. What would we do without this forum.
Even my dealer did not know that this was the case!
One other question: every time I plug my charger in, it needs me to input the PIN on the module. Is this the expected behaviour? Is that the main reason for the PIN? I was hoping the PIN was simply to lock the device so no one can make changes to settings but it seems like it is also so that no one can use the charger?
wemct
Georgia, USA
In the settings menu for the Porsche Mobile Charger Connect you can disable the requirement to enter a PIN. If for example the PMCC is located where someone else can access it, a PIN is useful to prevent charging. If the PMCC is inside your garage a PIN is less useful (I don't have a PIN requirement on mine).
Vim Schrotnock
Vim
Cincinnati
OK, let me throw in a wrinkle here. I'm thinking I'll set my timer to 7:30AM and my maximum charge profile to 85%. I'll set the temperature to have my car warm/cool to 71 deg so I'll get into a perfectly charged and climate controlled car every morning.
However, if I have a 7:30 AM timer set, and I return home from a trip with say 20% charge at 2pm and plug my car in, will the 'smart charger' say that I don't need to start recharging until later to hit 85% at 7:30? This would be a problem if I want to head out on another trip at 6pm.
Dee
Dee
A lot
No matter how "smart" a charger is, you have to tell it what you want.
¯\_(ツ)_/¯
Vim Schrotnock
Vim
Cincinnati
¯\_(ツ)_/¯
I'm just going with 'charge me to 85%' no matter what the time. Then I'll set the timer to have my car ready to go at the right temperature every morning before I drive to work.
Miwa
Bay Area, CA, USA
My wife's Bolt has a priority charge setting that immediately charges to 40%, and then it'll go back to whatever settings are set. (For her, that means 85% finishing at 5am).
The car asks every time you turn it off also what charge profile to use. So if you want something different, it's simple to change before you get out.
Gogs
Gordon
Aberdeen, Scotland, UK
In this case you would set the general charging profile to charge to 50%, so you come home, plug in, car charges to 50, then your timer will charge to 85 for 0730
Vim Schrotnock
Vim
Cincinnati
I think I'm good with the recent video and will simply keep the 85% minimum with no timer associated with the charging. This keeps things really simple, and I'll always charge to 85% when I plug in AC. The heat/cool timer, I'll use as shown in the video to have my car at the perfect temperature before I go to work.
Second question, is there a second timer like there is a second profile on charging, so you can set the car to warm/cool when you're leaving work?
Gogs
Gordon
Yes, just set a timed profile with no charging at the specified time you leave work.
lsbusymom
Leigh
United States
Porsche Taycan 2020
Ok, back to the original question for me, please. I have checked the profiles and the timers. They are all set to the same settings. The problem I have is that our car cannot tell time. An example. The time is 9:15 pm. I want the car to charge from 12 midnight to 6:45 am. As soon as I plug it in, it starts charging (no blue, only green). It will be charged to whatever percentage I ask but if I plug it in at 4 pm, it starts charging at 4 pm, even if it is not supposed to start until midnight. Any ideas?
Optimized charging
General
Timers
Profiles
Actually, not quite correct - 'Optimised' relates to the addition of a Home Energy Manager (HEM) for combining and optimising both solar and non-solar supply sources.
