My Preferred Multi-Screen Cabin Layout
ciaranob
ciaranob
A great thread!
I'm wondering about nightvision, it seems @ciaranob can choose it for the right "tube"? In my car I can only have it in the center tube.
I do find it negative that Porsche has decided that elements are reserved for one tube each. I would have had Information to the left and Trip to the right. To have both visible, I have Information in the right tube and MyScreen with Trip to the left, map in the middle and Media to the right there.
That I cannot have a compass in the Sport Chrono clock since I have a Sport Turismo is also remarkably silly.
My bad! - that was a typo re NightVisionAssist - have corrected the image and thx for spotting!
Will never happen but would have loved to see an option to display the NightVision in the Passenger display (but griped about that before :)!).
TDinDC
Washington, DC, USA
You can change the display on the dash wart? :oops:
Following up on this question, I assume others have different options for this, as I do not have the option to set a compass setting. I can (1) turn on clock; (2) turn illumination off and off; and (3) adjust brightness. What different options are there for this (e.g., I don't have FOMO but want to be sure I understand how/why others have different choices that I do)?
Thanks
My guess is that the handwriting feature demoed well internally in 2018 and either: a) some influential exec still loves it or b) nobody ever uses it, therefore there is never any complaints/feedback, therefore it has just been forgotten about.
I have never once heard a Taycan owner "in-the-wild" mention it – or a dealer during a demo either for that matter.
Just like the 3D parking view - looks flashy, so make for great demos, but completely useless when parking within a foot or less of anything, and/or next to any objects taller than 6 inches (curb height). Even after spending some time learning about the backup lines, still completely useless, for example when I pull into my garage, it always shows the backup lines that I will drive into my wife's car, yet I can see in the mirror I have plenty of room (enough to get out of the car).
I used the handwriting once, just like voice command for which I tried every possible combination of words I could think ok to turn the HUD on (such as show/display/enable/turn on HUD/Heads Up Display), every time it either told me it doesn't know what I want or it messed up my current navigation. I don't plan to use the handwriting again, so yea, complete waste of space.
Dublin, Ireland
www.targatrips.com
Imagine trying it with an Irish accent ?
Def in center display/tube for my 4S.
Same here. I with there was a "enable night vision in the center tube only when object detection is enabled" option. I keep it on 100% of the time because I don't want to have to remember to turn it on each time I think it's dark enough for the object detection to work.
Dublin, Ireland
www.targatrips.com
Oh, it is for sure working in the background at night – without needing any activation. I've had it pop up when it detected deer on a dark road for me.
The left tube shows up red with a icon of an animal and a warning: Collision Warning. You get a alarm sound and the centre "tube" shows the infa-red image with red box around the animal detected. All without having to manually configure anything.
The left tube shows up red with a picture of an animal and a warning: Collision Warning. You get a alarm sound and the centre "tube" shows the infa-red image with red box around the animal detected. All without having to manually configure anything.
Interesting and good to know that at least it will warn me if I'm about to hit something, even if night vision is not on the display. It won't warn ahead of time (one time on a highway at ~3am, there was an unlit, all in black, bicyclist in the middle of my lane, saw him on the night vision highlighted in yellow, but no collision warnings, perhaps because I slowed down to investigate and he rode to the side once I lit him up with the high beams - without the night vision it would have been dicey since at regular highway speeds I would have closed on him much faster).
EDIT: I wonder if that is different in the US, since things like flashing/highlighting an detected pedestrians/animals/obstacles with matrix headlights is illegal and therefore disabled here.
Dublin, Ireland
www.targatrips.com
For sure this stuff cannot be fully relied upon. But the theory is that its constantly calculating predicted paths for the people and animals it's detecting. If it predicts that there isn't a risk of the detection intersecting with your vehicle's path – it won't sound the alarm – and if the night vision screen is on – you'll see a yellow box around the detected object.
However, if it predicts that there is a risk of a path intersection (i.e. a collision) then you'll get the alarm and the display will show up, etc, and a red box is placed around the detected object.
How well this works, I've no clue.
In my case, the deer was actually on a steep wooded embankment to the side of the road – but running down it and towards the road. The car started to apply the brake and I did the same and brought the car to a near stop – and suddenly the deer – which I hadn't seen – ran across the road in front of us!
At least on that occasion – I was impressed. This happened while I had my 4S and I had left the night vision option off my pending Turbo S order – was trying to stick to a budget. The next day I added that option back onto the new car spec!
Edit: I'm 90% sure it's using Nvidia tech (hardware/software) for this – as well as road-sign/speed-sign detection.
ciaranob
ciaranob
Ditto - have had two incidents where deer have popped up and taken measures to avoid in west Texas back roads - tech has been around so long should be std in most lux cars imo :)!
Dublin, Ireland
www.targatrips.com
Also the system has no clue – and does not see or detect – footpaths (sidewalks). If a pedestrian is walking on one and you happen to meet them on a turn with the right angle – the system will trigger and freak-the-f**k-out. In Europe – using the matrix lights to flash some of its LEDs at them and might even jam on the brakes!
In theory – its supposed to know – from GPS data that its in an urban environment and not do that – but I've found that its idea of urban is "open to interpretation". Like most Porsche software!
TDinDC
Washington, DC, USA
I really like night vision even in urban environments (believe it or not, Georgetown has plenty of deer, fox, coyotes, and clueless pedestrians who pop out between cars to cross street in the middle of the block while watching phone and listening to earbuds).
