Avantgarde
- Eugene
- Apr 4, 2022
- Ann Arbor, MI
- 22' Taycan RWD PB+, 21' X5 Xdrive45e, 09' Cayman
I know every car is specced differently driving style, rubber composition all of these have different impacts on tire wear. All i was trying to debunk was the general misconception that "oh EVs are heavy so you should expect more tire wear". My point was "everything else being equal" a heavier car will wear tires faster. BUT at the same time "allLol ok.
Fwiw I did not argue premature wear is somehow built in or must be accepted - I simply rejected your comparison with a completely different situation. I’m at 10k miles on my original tires, and showing minimal wear. My 911 would eat its rears in less than 10k, it’s much lighter and on 17” wheels.
It’s all about being within spec (for alignment and air pressure), and driving style.
Agree every car tire is specced differently, rubber composition driving style all of these have different impacts on tire wear. All i was trying to de-bunk was the common argument that "oh EVs are heavy so you should expect more tire wear, don't get surprised" - and I hear dealer advisors use this to justify pre-mature tire changes. My point was "everything else being equal" yes a heavier car will wear its tires faster. BUT at the same time tire diameters got significantly larger over years (particularly so for Porsche) and you are buying significantly more rubber everytime you change your tire compared to 10 years ago, which should more than negate the weight impact-again everything else being equal.Ok, so we both understand simple physics. ? The only point I was trying to make is that the compound engineered for 10k of wear on a 2015 3 series on smaller diameter wheels is not the same as that put to work under a Taycan on 20”. Tires, as I’m sure you know, are rated for wear, traction and temperature as a unit and not per sq cm of contact patch. I bristled at the revolutions argument as that is already reflected into a given tire’s rating.
