Donar
- Dec 6, 2023
- Netherlands
- Taycan ST ‘22 - Polestar 2 Performance '20
- #1
I know there are a lot of threads already regarding charging, but I’m so annoyed with charging behavior of my Taycan that I would like to know if there is some kind of method to reset all charging profiles and timers.
Before I had one profile and one timer. Was working perfectly fine. But I wanted to finetune a bit and now it’s broken.
I already deleted everything, but no matter what I put in now, my Taycan will only (1) charge directly to the profile minimum and (2) charge immediately if I select that option.
Currently I have 1 profile with preferred times. My Taycan does charge to the minimum of that profile, but then it falls asleep and does nothing with the set timing. It should just start and stop.
Also adding timers does not do anything. As said: it looks like it falls asleep after the initial charge to the minimum and whatever else I program it doesn’t wake up.
For now I will fix with the minimum charge, so it will charge to whatever I select there, but I would prefer to charge at night again.
